Adding Auto-Dimming Mirror??
I have a 1988 Toronado Base that I would like to add an auto-dimming mirror to. It came factory with a manual dimming mirror. I bought a factory Automatic one that was supposed to come out of a '87 Toronado, which has a 3 pin connector. I found a 2 pin connector behind the roof console with the map lights in it, so I assumed this was for an auto-dimming mirror. If anybody could help me out with this issue I would appreciate it! The original mirror is going bad so if I can add this upgrade that would be sweet!
It’s really easy to swap the auto dimming. Technically, all you have to have is a key on power source and a ground. There is a 3rd wire (green) that is suppose to connect to the reverse lights. Put the shifter in reverse, the mirror goes clear.
read this. I’m still working on a custom mirror housing to hold the compass electronics. It’s on the back burner, if I could bring myself to glue the mirror mount you the windshield it would be done by now.
https://classicoldsmobile.com/forums/classicoldsmobile.com/forums/showthread.php?t=127003
and read this https://classicoldsmobile.com/forums...ad.php?t=12966
