Ignition key buzzer/seat belt buzzer don't work..
Old May 5, 2020 | 08:01 PM
72455's Avatar
1972 U code Supreme
Hey all,
Since the pandemic has gotten us all on pause from cruze-ins and car shows, I'm tackling various projects on my "to do" list that I've been putting off.
Two of those projects are getting the seat belt buzzer and ignition key buzzer to work on my '72 Supreme. They haven't worked since I bought the car two years ago, so it's time to get to work.
I was going to start with the obvious and check the relay, but I dunno if the picture I have attached is it, and is it for both the seat belt and the key buzzer? Also, how do I bench test it to see if it works? This is on the driver side firewall just underneath the cowl tag.
Finally, if the pic isn't of the relay in question, where is it?
Thanks, and Happy Oldsmobiling!
Dave
Old May 6, 2020 | 04:21 AM
Well, I don't know about the seat belt buzzer, as my 71 doesn't have it, but the key in buzzer is the horn relay which is on the left fender and has all the wires from the positive terminal on top.
Old May 6, 2020 | 04:27 AM
Look at the thread below "Door Buzzer".
Old May 6, 2020 | 04:37 AM
green1972's Avatar
if its a supreme the horn relay is in the middle of the firewall just above the distributor, I believe there are two plugs that go into the bottom of it , check to see if they are plugged in, usually everyone unplugs it there, Tim
Old May 6, 2020 | 06:00 AM
72455's Avatar
1972 U code Supreme
My horn relay is in the center of the firewall and all of the wires are connected. The relay is good cuz my horn works. Not really worried about the seat belt buzzer right now, but would like to look into the key buzzer. Do I have to dig into the steering column? If so, then I'll leave it alone.
And if the pic isn't the key buzzer relay, then what is it?
Old May 6, 2020 | 06:06 AM
green1972's Avatar
ac relay i believe, its by Brake booster?
the buzzer is up under the dash by the back of the ash tray, a lot of times people just unplugged it
Old May 6, 2020 | 06:11 AM
72455's Avatar
1972 U code Supreme
Yep, it's by the brake booster, so thanks for that. I'll check the buzzer on a nicer day...chilly and drizzly here in SE VA today.
Old May 6, 2020 | 08:27 AM
Tedd Thompson's Avatar
If they are both non op you are a lucky man. I hate those things and automatic door locks also... Tedd
Tiberian Fiend
Feb 12, 2019 02:51 PM
NDERISE
Feb 18, 2014 08:20 AM
terrapin
Aug 3, 2012 06:08 AM
ELECMAN
Jan 26, 2010 10:59 AM
kimberlies7
Sep 9, 2009 08:18 AM
