Overhead seat belt issues
Old Sep 8, 2009 | 09:18 AM
kimberlies7's Avatar
Kimberlies72
does anyone have pics or diagram of front overhead seat belt assembly...not sure how to install since the headliner was redone and the holes were covered up...appreciate any help...thanks
Old Sep 8, 2009 | 09:20 AM
mugzilla's Avatar
is Fast Enough ...
I left mine off ...
Old Sep 8, 2009 | 10:35 AM
Kimberlies72
not sure if that was legal...need to pass an inspection, i have a salvage title
Old Sep 8, 2009 | 10:36 AM
I'd worry more about my face contacting the dash board...
Old Sep 8, 2009 | 11:45 AM
Kimberlies72
whats that suppose to mean...just wanted some info or pics
Old Sep 8, 2009 | 12:34 PM
That's supposed to mean that the reason I use seat and shoulder belts is not to stay "legal", it's to keep my face off the dashboard in an accident.
A feeble attempt at humor...
Old Sep 8, 2009 | 12:37 PM
This thread should help you get started.
https://classicoldsmobile.com/forums...eat-belts.html
Old Sep 8, 2009 | 02:44 PM
mugzilla's Avatar
is Fast Enough ...
Yes but it lightens the car by 2.5 lbs ...
Old Sep 8, 2009 | 02:52 PM
mugzilla's Avatar
is Fast Enough ...
I'll dig around in my pics ...
The thread listed does not seem to show the holes for the wire loop belt holders for when the shoulder belt is not used ...
brb ...
Old Sep 8, 2009 | 05:39 PM
mugzilla's Avatar
is Fast Enough ...
I can't believe it. My camera takes 2000 pics a card, I thought I took a pic so I can install the belt and this is the best I could find.
Old Sep 8, 2009 | 06:45 PM
2blu442's Avatar
Can you use that photograph then press with your fingers in the approximate location to feel the 2 bolt holes? Do you have the shoulder strap belts? I may be able to photograph that area without the strap bolted in, but it would probably be next weekend before I have the time. John
Old Sep 8, 2009 | 08:11 PM
sixty9olds's Avatar
You didn't say what type of vehicle you’re working on, but I am assuming from your avatar that it is a 1972 Cutlass.
I took a couple of pictures of my 1970 Cutlass Supreme Shoulder belt mounts. One important note here, make sure that you use the correct grade 7 bolt for mounting the shoulder belt. Do NOT get any old bolt from the hardware store. These 2 bolts are the only things that keep your head from hitting the windshield, steering wheel, or dash board (as Joe pointed out). If you look closely at the picture of the bolts you can see the number 7 stamped on them.
The assembly order for the components would be headliner, decorative cover, seatbelt anchor and lastly the bolts.
This picture is of the passenger side with the cover installed.
IMG_1025.jpg?t=1252464628
Second picture of driver side with decorative cover open.
IMG_1026.jpg?t=1252465802
Old Sep 8, 2009 | 10:41 PM
mugzilla's Avatar
is Fast Enough ...
Yes the year is important, look at my '70 hardtop with the large rib ...
also what about the wire hanger holes ..?
Old Sep 9, 2009 | 03:29 AM
Yellowstatue's Avatar
Thumbs up Search carefully
When you find the approximate location of the holes, use a very tiny needle or pin to locate the hole and mark it with a pen or marker... Do not stick the needle or pin in your finger...it will smart greatly...ask me
Old Sep 9, 2009 | 03:55 AM
I would think the steering wheel would stop him from harming his dash.
Old Sep 9, 2009 | 08:18 AM
Kimberlies72
Thanks for the help...info and pics, should be a help...72 Olds Cutlass
Rocketbrian
Jan 20, 2015 06:59 AM
djhoth
Jan 24, 2012 09:33 AM
Olds98
Aug 6, 2010 05:02 AM
shine
Mar 29, 2008 02:41 PM
pompman
Oct 22, 2006 08:20 PM
