shoulder seat belts
shoulder seat belts
Does anyone know of any photos of the interior of a 72 with bucket seats with shoulder seat belts? I would like to as some to mine and would like something for reference.
For this year I believe the bucket and bench seats used the same seat belts and shoulder straps. Attached are some photos of a 1972 seat belt and shoulder strap. Let me know if you have any questions. John
You'll also have to attach the sleeve the belt rests in while it's not in use. It goes above the windows and attaches to the reinforced structure of the upper roof line. John's pictures (nice clear pics John - I need a camera like yours) shows the structure and the "peanut shaped" slot the belt has to lock into really well. The other belt with the large round insert is what you put into the peanut and then seat it. The owners manual says to leave just enough clearance as your fist for wiggle room. yuch.
Personally, I only use the lap belt since I find the shoulder belt combo really constraining. It's NOT like the harneses in todays cars that allow you to move and breath. Put on the 1972 shoulder belt just once and you'll know why no one wants to wear it.
I have 72 convertible. In replacing the hoses for the top, I had to remove the interior trim to access the lift cylinders. In the process, I found seat belts attached to the body of the car that I can't seem to figure out how they were used (if ever) They have a "female" end on them. My digtal camera broke so I can't post any photos
is restoring his 72 vert. He's done the whole interior so if anyone can tell you what's up, or how to do it, that would be him. You might want to search through some of his posts on "restoration of lady" to see some of the fantastic work he's done. I'm not saying he's the only one out there who knows what's going on, just that I've seen his posts/pictures and he definitely does quality work. Good luck with your project.
Was the car originally sold in Canada? Shoulder belts were mandatory for US cars (except convertibles) from the 1968 model year onward. Shoulder belts in convertibles were a very rare option in those years.
And the gov't here requires the use of daytime running lights as well. They say it helps make the car more visible to oncoming traffic. DRL only use 25% of the low beam. My neighbor winters in Palm Springs and bought a Ford Fusion that he brought across the border. In addition to the paperwork, he had to pay Ford of Canada 1100.00 for the control module to be installed for DRLs. Would have been cheaper to buy it here. Nowadays they can't give cars away. No one's buying because of the economy.
Okay Allan, stop making me
Shoulder belts were mandatory in 1972 and later, although many convertibles were still exempt.
The 1972 Olds literature, did spell out that shoulder belts came with the car with the "except convertibles" notations. They were not even an option then in the Cutlass 'vert'.
The body manuals do not show them in any form for either.
I see no good, safe way to add shoulder belts to a 72 'vert', without a lot of extensive labor and unreversible mods to the car.
We have seatbelt laws in TX and so far I have never been stopped for no shoulder belt. If I ever do, I just tell them the car did not come with them (and I have the documents that back it up should I need them!)
1100 for a DRL module? Forget that! Just use the light switch instead!
Actually, DRL would be easy to install on our Olds (or most any car) for about 10 bucks.
Power a new relay off the defogger relay feed (or from the GEN light terminal on the regulator if the car has no defogger) and wire the headlights to the new relay. Then all the lights come on after the engine is running... If less brightness is required, wire a big-honkin' resistor in series...
Power a new relay off the defogger relay feed (or from the GEN light terminal on the regulator if the car has no defogger) and wire the headlights to the new relay. Then all the lights come on after the engine is running... If less brighness is required, wire a big-honkin' resistor in series...
but I'm sure most will be able to recognize the pattern.About the extra relay, won't this interfere with the headlamp delay option? It works on a pressure switch (the oil pressure sensor) for the rallye-pac.???
I am sure with the right relay(s) and wiring diagram, this basic circuit could work with a delay circuit. Of course I would not try this on any car that uses a computer module to control the lights.
Now rigging up a switch on the shifter that turns the lights on when in "drive" would be the more keen idea and would easily work with the delay function...
Hmmm.... Maybe replace the inner high-beam onlys with high-low beam units like the outers and connect the inner low beams together in series to the new relay, and have another relay to disable them while the main lights are turned on................. Great, now I have the urge to go home and look it all up!
But wait - I don't need no stinkin' DRLs!!
Okay, my $10 fix does not have the cute green indicator - might as well get the $1100 one - no prob! GOTTA have the green light on the dash!!
Course I would not try this on any car that uses a computer module to control the lights.
Ha Ha my friend, not too likely, I wouldn't spend the money either
Me either, some of these things scare me to death because as an electrician I'd make a good plumber
Me either. They stay only on the cars that came with them. Not going to touch my Cutlass
You and me both, nice to see you still have your sense of humor
Ever see a plumber blindly cut into a wall above a wall outlet?still???
You must have read my interior thread where I screwed up on the carpet trimming...
Yes I did recover after the beers in the brain saved the day...
My 1970 convertible has front shoulder belts, the assembly manual shows how they get installed. If folks need them I can scan the drawings in. I have only seen one other convertible from that era with them installed. In 1970 even the back seats had an option for sholder belts.
Interested in how that was done.
'72 vert seat belt
stlbluebrother,
Is there some kind of slot in the piston cover for the rear shoulder belt, or does the shoulder strap get sandwiched between the ash cover and the piston cover? I'm restoring a '72 vert; didn't find any shoulder belts but the lap belts have the extra hole at the buckle end for the shoulder belt to clip into. See attached pic.
Just so you know, '70 seat belts are different from '71 and '72.
The '70s are plain buckles (one for lap, one for shoulder), the '72s (and I believe the '71s) have the keyhole interlock and a single receptacle.
'71 no keyhole slot
I have a '71 Supreme waiting to be my next project, so I checked the frotn buckles. My '71 does not have the keyhole slot like the '72. But this brings to mind another question about rear belts, when did the rear seat belts become retractable? I had a '71 convertible that the seat belts did not retract; instead of retracting, they clipped into "holders" that were mounted to the front edge of the bottom seat cushion. I think my '71 hardtop (the sweet car, I never should have sold, shown in my avatar) had the same arrangement in the rear. Just wondering what is correct.
72 as well.
My clear plastic is yellowed as well. Interestingly your other plastic part is gold which matches the webbing. Mine is black since my webbing is black as well. I would have thought they'd make all of those black and not bother matching the color of the seat belts.
In the attached picture you can see the clear plastic sleeve Steven mentions. Mine has become discolored with time.
Attachment 58621
Attachment 58621
Good morning, I know that this is one old thread but I couldn't find any recent information on the 72 seat belt set up. I am in need of the lap belt for a strato bucket for the passenger side. Both, the male and female with the added slot receiver for the slotted shoulder strap. Does anyone have any information on where I can buy these? Or does anyone have any information on the conversion? I also am in need of the plastic shoulder strap trim that holds the shoulder belt in place when not in use.
jcmoretti
Jul 11, 2018 03:07 PM
