Fuel gauge not reading correctly
Old Jun 18, 2020 | 05:46 AM
Billyaxe's Avatar
On my 68 442, my gas gauge reads 3/4 when actually full. Then when at half a tank it the needle stops at 1/4 and doesn’t go any lower. What does that sound like is going on?
if I drop the tank to replace the sending unit, are there any other parts to replace while I’m in there? Thanks —Billy
Old Aug 18, 2020 | 06:24 AM
Billyaxe's Avatar
Following up on my last message that got no reply: I found out that the fuel send was replaced by the previous owner and didn’t fix the problem. Is the problem usually anything more than the float? If I’m having the tank dropped, should I put a new tank in? Please help. —Billy
Old Aug 18, 2020 | 06:41 AM
RetroRanger's Avatar
72 Olds CS
You can test the guage travel by grounding it, the gage should go to e or w an open Circuit it should goto past full.
if that works fine maybe you have the wrong sender or thesender cant travel its range because its bent or something is stopping it. The senders have a range of resistance that makes the guage travel its path from f to e if the resistance range is incorrect you will get in correct tank readings
Old Aug 18, 2020 | 09:09 AM
The reason it got no reply is because you resurrected a 5 year old thread with an unrelated issue. Moved to its own thread.
Old Aug 19, 2020 | 06:17 AM
Billyaxe's Avatar
Thanks I’ll do that test. —Billy
PatL
Aug 3, 2020 06:39 PM
Sampson
Oct 10, 2018 03:53 AM
Sportcoupe
Jul 17, 2017 03:07 PM
Designosaur73
Aug 4, 2013 02:25 PM
Vyse
Nov 10, 2010 07:18 AM
