Inaccurate fuel sender
Old October 8th, 2018, 10:18 AM
Sampson's Avatar
Last fall I had the fuel tank out to fix a leak around the fuel sending unit. The sender and gauge worked correctly but the gasket leaked. I had already purchased a new sending unit prior to dropping the tank just in case I needed, so I used the new one, instead of just replacing the gasket. Now the gauge only goes to 3/4 and drops rapidly towards empty. Somewhere between E and 1/4 is really a 1/2 tank. My questions: is there anyway to adjust without dropping the tank again? Is there a way to adjust the sender after dropping the tank or do I have the wrong or faulty sender? Thanks for any input. Steve
Sampson is offline
Old October 8th, 2018, 10:29 AM
mrolds69's Avatar
I don't know of any replacement sender that's accurate. They all pretty much do what you mention. Even some "NOS" GM senders you find now do that. You can't adjust it w/o dropping the tank again. I suppose if you are electronically savvy you could put a resistor with a rheostat under the dash somehow. It's easier to drop the tank. There's a long thread about the sender probs on one of the Chevelle forums.
mrolds69 is online now
Old October 10th, 2018, 03:53 AM
Unfortunately the tank needs to come back out and you need to adjust the swing arm. If you still have the original, you can use it as a guide to bend the arm to match.
oldcutlass is online now
jc1671
August 24th, 2018 02:02 PM
rothlane'68
September 7th, 2017 05:31 AM
Sportcoupe
July 17th, 2017 03:07 PM
442craig
September 11th, 2014 02:07 PM
irydasteelhorse
March 3rd, 2012 05:40 PM
Quick Reply: Inaccurate fuel sender
