horn button assembly oldsmobile 1959 dynamic 88
Old May 18, 2020 | 10:30 AM
Primator's Avatar
Hello iam trying to restore my steering wheel on my oldsmobile 1959 88 and i cant get the horn buttons to work i dident have a 5mm Cooper pin so i used a 6mm and drilled the hole in the steering wheel to 6mm and i soldered a wire to it and connected it to the buttons i dont know if a 6mm pin is to big or so when i put the steering wheel on it grounds and the horn sound all the time. Iam not sure how to connect the buttons anyone know?
Old May 20, 2020 | 05:27 AM
Primator's Avatar
Hello?
Old May 20, 2020 | 07:43 AM
Tedd Thompson's Avatar
I'm ignorant on 59 stuff but have you checked to see of it is indeed shorting out at the pin and not at the rubber insulator on the bottom? If it indeed even has a insulator like the earlier cars. What does your manual show, should be a diagram showing a breakdown of parts...... Just guessing.... Tedd
Old May 20, 2020 | 06:16 PM
Charlie Jones's Avatar
Phantom Phixer
Does this help ?
Old May 21, 2020 | 07:38 AM
Well now I can see that a 59 isn't anything like what a 55-56 is built like.
Charlie, wish I had your library to do research by. Po. please disregard my previous post... Tedd
Old May 21, 2020 | 07:58 AM
Phantom Phixer
Tedd , you haven't downloaded the 1963 Olds parts books yet ?
Free downloads , links here ;
https://classicoldsmobile.com/forums...dition-131501/
https://classicoldsmobile.com/forums...dition-131503/
KQQLCAT
Mar 31, 2020 05:23 AM
QS442
Feb 19, 2020 07:21 AM
69CutlassAlex
Jul 28, 2014 06:54 AM
kbdecatur
May 13, 2013 04:26 PM
RPMRestoAndCustom
Jul 16, 2012 04:29 PM
