1954 Oldsmobile Horn Problems
Old Mar 26, 2020 | 05:18 AM
KQQLCAT's Avatar
54 Oldsmobile horn doesn't work. I think something is missing in the horn ring. Does anyone have a break down of parts in the steering wheel?
Thanks,
Pat
Old Mar 26, 2020 | 08:43 AM
Tedd Thompson's Avatar
Pat, Does your horn (should be horns) work if you jump a hot lead to the horns for a start. If yes check for juice at the horn relay, both sides where they attach at the junction., if yes on the inside under the dash near the top of the steering column there should be a pair of wires with bullet connectors check there, if yes remove the steering wheel and check if you have juice at the base. Quite often the grounding shield (big black rubber donut) has deteriorated and will need to be replaced but when it goes generally the horn will go off on it own when you touch the wheel.
I don't have my book here so this may be out of order all this is from my foggy memory. There should be a washer a plate and a bakelite disk that holds a spring and a detent in a cup that makes the connection from the horn ring to the ground on the wheel. If anything will get lost it would be that spring or the bakelite disk sometimes crack and fall apart. Sorry this is so longwended a picture is worth a million words and I used up most of them..... Tedd
Old Mar 26, 2020 | 01:25 PM
KQQLCAT's Avatar
Ok I think the spring is missing because there is not one in there. I replaced the rubber piece. Someone must have taken this apart before me because I never saw a spring.
Pat
Old Mar 26, 2020 | 03:09 PM
2blu442's Avatar
Here's an old thread that shows the parts of a 1955 steering wheel/horn button assembly. Tedd, I'm thinking this would be the same or similar as the 1954?
https://classicoldsmobile.com/forums...ssembly-98828/
Old Mar 26, 2020 | 05:52 PM
John that's much better than my rambling, I forgot about the sheath around the spring and detent...... Tedd
Old Mar 27, 2020 | 02:52 AM
ignachuck's Avatar
Frank Ignachuck
Pat, you said you already have the rubber horn cushion. Fusick also has them.
The horn contact spring brush is hard to find. I did find one on this website that MAY fit:
http://www.classicpartsusa.com/produ...SABEgKFtfD_BwE
Old Mar 27, 2020 | 05:50 AM
KQQLCAT's Avatar
I looked at that thread and its very similar. Didn't see a spring in that one either.
Pat
Old Mar 31, 2020 | 05:23 AM
KQQLCAT's Avatar
My question is what makes a ground when you push horn ring?
Bee Saint Louis
Oct 28, 2017 07:45 AM
Oldsr4me
Oct 5, 2016 08:19 PM
W-27
Aug 24, 2013 10:12 AM
RPMRestoAndCustom
Jul 16, 2012 04:29 PM
jean_ed
May 26, 2010 11:25 PM
