Oldsmobile Delta 88 Royale 1978
Hi everybody,
I recently bought the car with a low mileage and good condition.
Although motor turns nicely does not start. there is not spark. Anybody knows of any immobiliser like the Cadillac?
Theo
Theo
The easy thing is to temporarily run +12V directly to the BATT terminal on the distributor cap. If you get spark, the problem is in the wiring from the ignition switch to the distributor. If you still do not get spark, the problem is in the distributor itself. Failed HEI modules are not uncommon, but that is not the only potential cause.
ddd777
Aug 5, 2015 05:12 PM
