Oldsmobile Delta 88 Royale 1978
Old May 9, 2020 | 05:51 AM
tmarkitanis's Avatar
Hi everybody,
I recently bought the car with a low mileage and good condition.
Although motor turns nicely does not start. there is not spark. Anybody knows of any immobiliser like the Cadillac?
Theo
Old May 9, 2020 | 07:45 AM
Originally Posted by tmarkitanis
Hi everybody,
Theo
There is no VATS or similar system from the factory on that car. No telling what a prior owner may have done.
The easy thing is to temporarily run +12V directly to the BATT terminal on the distributor cap. If you get spark, the problem is in the wiring from the ignition switch to the distributor. If you still do not get spark, the problem is in the distributor itself. Failed HEI modules are not uncommon, but that is not the only potential cause.
Old May 9, 2020 | 10:21 AM
Thanks Joe,
I will try what you explained and take it from there. Maybe the previous owner fitted something.
thanks again
Theo
Old May 9, 2020 | 10:25 AM
Be aware that if the car does start with that temporary power wire in place, you'll have to physically disconnect the wire to turn the car off.
Old May 9, 2020 | 10:28 AM
I understand. I have some knowledge of old cars.
Thank you Joe
tmarkitanis
May 11, 2020 11:48 PM
boese1978
Mar 1, 2017 05:17 AM
ddd777
Aug 5, 2015 05:12 PM
Walker Mitchell
44
Jul 3, 2013 02:27 PM
Tennesseeolds
Cars Wanted
Feb 19, 2012 02:40 PM
