Alternator rebuild
Old Jul 20, 2020 | 06:24 PM
jharsh's Avatar
Alternator rebuild
Looking to rebuild a 1100777 55 amp. alternator and trying to find parts.
Is this alternator considered a Delco Remy 10DN Alternator?
Any good recommendations for parts vendors?
Thanks,
Old Jul 20, 2020 | 06:48 PM
Yes, that is a 10DN. I use Standard Motor Products parts. Just be sure to use their top line and not the "T-series" line.
Old Jul 20, 2020 | 08:30 PM
RandyS's Avatar
You will need a press to install the new diodes. Hammering them in doesn't work so well.......
Old Jul 20, 2020 | 10:18 PM
I replaced the diodes back in the early 90s but I don’t really remember how I got them in. I didn’t have any type of press, so I probably used a hammer and a socket the same size as the OD of the diode body to protect the lead from damage while I tapped it in.
Old Jul 20, 2020 | 11:39 PM
oldsonharmont's Avatar
It's a bit far from you, but you might try calling this old school rebuild shop in Glendale, Az. Gary the owner is a very knowledgeable and helpful guy.
http://genstarelectric.com/
Old Jul 21, 2020 | 07:34 AM
RetroRanger's Avatar
72 Olds CS
Stellar on this site is a knowledgeable rebuilder With parts access.
Old Jul 21, 2020 | 02:37 PM
jharsh's Avatar
Thanks for the reply's.
Old Jul 22, 2020 | 01:23 PM
matt68F-85's Avatar
I used a socket and a bench vice to press in the diodes, worked well.
Old Jul 22, 2020 | 01:26 PM
matt68F-85's Avatar
correction, it was an old caliper bushing with a slot cut in it for the wire, not a socket.
Bernhard
Dec 3, 2020 10:44 AM
capstoneclub
May 4, 2013 08:39 PM
442b
Sep 1, 2011 12:00 PM
johnspd22
Apr 4, 2010 04:44 AM
war eagle
Feb 20, 2009 12:34 PM
