Tips on '51 dash removal?
Old Apr 2, 2020 | 06:19 PM
aljmann's Avatar
I have a non-functioning R dash indicator light and speedometer.
Any tips regarding dash removal and access would be appreciated..............
Old Apr 2, 2020 | 09:14 PM
Ozzie's Avatar
Dash removal sounds like a bit of overkill for the problems. The indicator light may just need a lamp replacement. The speedometer problem likely needs more investigation to determine the nature of the problem. It might just need a cable replacement.
Old May 6, 2020 | 12:00 PM
aljmann's Avatar
Hello again, all.
A new cable made no difference - still lots of grinding noise and the dial showing about 4x my actual speed. My mechanic Michael removed the instrument cluster without much trouble, and plugged the oil pressure pipe. I am looking for recommendations on speedometer rebuilders, especially on something of similar vintage to my 1951 model.
Thanks!
Andrew
Old May 6, 2020 | 07:02 PM
Ozzie's Avatar
Originally Posted by aljmann
Hello again, all.
Thanks!
Andrew
Considering the type of speedometer malfunction you are experiencing you will need the help of a speedometer repair shop. You can do a search on the forum or with Google to find one that can work on your vintage. Call them and tell them what the problem is in detail including the make & year.
Old Sep 22, 2020 | 07:58 PM
aljmann's Avatar
Update
The instrument cluster unscrews from behind/below the dash (but it seems only I didn't know that) with two knurled nuts and two more nuts holding brackets in place.
BOBSSPEEDOMETER.COM rebuilt the speedometer and it now works almost totally silently. They were courteous and quick.
Tuffnut
Mar 9, 2020 05:40 PM
fv64olds98
Jun 14, 2013 10:55 PM
Doomah
Jun 11, 2012 01:35 PM
centonze
Feb 29, 2012 09:00 AM
Redog
Jun 25, 2011 10:17 PM
