Hood / Trunk Light Power Source?
Have a 1966 Toronado with original hood & trunk lights mounted. The feed wires have been cut to both.
They both have mercury switches in the sockets. I'm guessing the cut feed wires are hot all the time.
There is also a courtesy light switch on the dash, but it has no effect.
Anyone know where the power source is coming from?
Thanks!
Thanks!
Is this where I get to say "look in the Chassis Service Manual"??? PLEEEZE?
The trunk light is powered from a brown wire in the rear lamp harness (not to be confused with the tan wire to the fuel tank sender).
The underhood light is powered by a brown wire that passes through the firewall grommet.
Both are hot all the time and fed by the 9A fuse labeled UHOOD GBOX LAMP.
Another good idea. Iv'e been taking pictures of whats left of my wiring diagram & zooming in on it-just gets a little grainy.
Which doesn't apply to a 1966 Toro...
For some reason Yellowstatue's 1968 Cutlass works the same as this 1966 Toronado. The 9 amp fuse is dead when the headlights & parking lights are off-then goes hot whenever either are on. I was glad to see them both working correctly (mercury switches) after I reconnected them.
However
Because I connected the LED brow lights to that same Brown parking light wire, I may have inadvertently jumped that circuit.
Just wanted you to know.
Dave
Just for clarification, the underhood lamp on a '68 A-body is supposed to come on when the hood is lifted. The parking lamps/headlights don't have to be on. This changed on the '69 A-body to the underhood lamp being dependent upon the parking lamps being on for the underhood lamp to work.
Randy C.
'68 4-4-2 convertible
'69 4-4-2 convertible
Randy C.
