View Full Version : Electrical
- Won't turn over
- Engine Harness question
- OOPS I din't notice! 66 Olds Cutlass
- Reverse Light Wiring - remove bumper?
- 1952 Starfire blinker issue
- How to multimeter test wiper motor?
- Fuse Block Toronado help
- Anybody Know 65 Cutlass Dash Wiring?
- Isn't there something missing???
- Power to voltmeter
- wiper motor wiring picture?
- 67 Cutlass - Mess putting fuse block back
- 1956 Brake Light Problem
- Can this be saved!
- olds 455 ignition retards by itself
- Slow turn signal
- Lost 12v at IGN spade on fuse block
- Radio repairer
- Need help w/ switch pitch electrical
- 1965 442 Ground Question
- Secret Audio with stock stereo
- Windshield wiper motor connector
- Wiper Arms Parked on hood...
- Shorted Pos cable on exhaust manifold
- Original Power Cables
- Need some fast help with headlights
- Electric windows kickin my butt
- Courtesy Lights
- 71 cutlass antennae
- radio blue wire
- Strange Alternator issue
- Console lighting
- Wires, wires everywhere.
- front turn signal connector
- Alternator internal testing? (internally regulated)
- What is a good cleaner for a fuse Box??
- Alternator wiring
- Optima battery's
- Problem with radio
- 65 442 One Brake Light Dead, No Dash Lights
- Battery
- relay for fuel pump
- starter decode? (and heat soak)
- Externally regulated to internally regulated alternator without using jumpers.
- 92 Supreme Fuel Gauge Pegged "Full"
- Auxiliary install ?
- 65 442 Electric Choke Question
- so whats the trick to get to the Cigar and radio
- Aftermarket Blower Motor for 67 442?
- Battery Relocation - 1967 442
- Electrical problem with washer pump
- 69 Cutlass Cigarette Lighter Housing
- Where or what do these go to?
- 1990 Delta 88 Wont Crank
- 1965 442 Alternator Conversion Question
- dash lights 1965 cutlass
- rewiring for dome light
- 1970 442 Y92 Courtesy Light Package
- Help with electrical wires
- 1990 Oldsmobile Delta 88 Problem
- TH400 kickdown switch replacement
- 1966 delta 88 Neutral Safety Switch
- Battery topper
- 57 fiesta brake lamp switch wiring. need help
- Heater/AC fuse keeps blowing on the '66
- AC COMPRESSOR help
- Not all cylinders running always - plug wire resistance
- What is this?
- Accessory radio remote turn on
- 1967 oldsmobile
- hazard switch confusion.
- 68 Sport Wheel Horn Connection?
- Headlight Relay Help Needed
- Help Please! Blower for A/C quit working
- Turn signal / parking light problem
- 57 fiesta wiring help
- 69 Cutlass headlight, turn signal and brake light problem
- 69 Cutlass headlight switch problem
- simple I know...
- detent switch
- Distributer pricing
- Wiring Harness that connects to rear steering column....
- '68 442 electric
- 1972 Convertible top power to motor
- Horn testing...
- New Horn Relay goes sparky sparky
- Stumped on turn signal issue
- Courtesy Lights
- AC fan resistor wiring
- Horn Diagnosis....
- 68 442 door ajar switch
- What is a distributor-type inductive ignition system?
- Wiper diagnosis help
- Alt overcharging
- 85 Cutlass supreme window problems??
- 73 Delta 88 Royale window relay
- help, my 67 cutlass oldsmobile won't start
- Passenger Side High Beam not woking wiring
- 68 cigarette lighter
- AC Problem with error code 66
- Troubleshooting a 72' T T Tach....
- ext reg to int reg alternator swap.
- What is this?
- Electrical connector question on '56 Olds
- Need 67 Cutlass AM/FM Radio Model #
- 71 350 MT what is this bit of wiring?
- Another Rally Pack install problem
- voltage surge
- No Start. Stumped (so far).
- 1972 Cutlass Convertible Wiring?
- 98 Intrigue blower motor not working
- 67 Cutlass - Wire harness gaskets
- '70 Fuel/Idiot Lights Unit Lighting - Weird Issue
- 1968 A Body Courtesy Harness Connections
- Possible issue with rear defroster
- Fuel gauge/tell tale help
- Clutch safety switch
- '67 442 Rally Pack Fuse
- '67 442 Trunk Wiring Help
- Need help with wire harness
- 1962 Oldsmobile 98
- dash turn signal and high beam warning light
- Blower motor testing
- DVCS delete but what's this?
- Power window harness
- flasher?
- 1970 Cutlass taillight housing repair question
- Chrome altanator
- Does this Junction box look overloaded
- 79 h/o guages
- How to replace a wiring harness
- Installing Sunpro gauges
- 66 442 Gas Tank Sending Unit Connector
- Power master starter
- Courtesy light near e-brake
- 1968 Cutlass wiring diagram
- Need help with brake lights / signals
- 1969 Clutch Start Switch
- 1970 turn signal switch logic
- No fire!
- 72 Cutlass cont motor switch
- '56 Instrument Cluster Fuse
- Would 2 alternator output wires to reduce heat?
- volts
- Charging issues.
- Please help. Blower fan won't turn off.
- Horn Notes on a 1968 Cutlass
- Will These Voltage Regs Work?
- windshield wiper question
- 1985 cutlass rally pac
- Battery drain, had an oops
- Engine block shows 12v??
- Wiring woes
- Need help finding correct signal switch for 1968 Delmont 88
- ignition switch removal?
- parking lamps/head lights
- 1946247 Ballast Resistor ?
- Pulley for a 1954 Olds 88
- wiring harness and cut wires.
- Options for repairing instrument panel printed circuit board
- Replace fusible link with modern fuse
- Heater fan remains on even when heater off.
- 66-67 convertible top switch and bezel
- Starter for a 1970 442
- Brake lights do not work, turn signal relay
- Shot in the Dark
- '72 Delta 88 no brake lights/hazard lights
- 68 delta 88 dash light ghosts
- HELP: 67 cutlass dash lights and dash removal???
- New Start motor causing smoke and sparks
- Help with harness rear body/tail light
- 56 Lighter Question
- All interior lights/accessories working EXCEPT speedo/fuel gauge.
- 1970 A body Wiring diagram
- wiring diagram for 1970 cutlass
- Turning Signal isn't working
- Gauge Resto
- Alt to Vot reg wiring strange
- Tail light question
- 64 Dynamic 88 Turn Signal Switch
- Fan not working. Is it Fan or Switch
- 1961 Olds 88 gen light on help! Volt reg fuse?
- Repro Rally Packs
- Can't find replacement part for air conditioning thermal switch, part number AC13CM
- 68 cutlass gauge lights not working
- Fuse block
- windshield antenna
- Door Buzzer Randomly Went Off
- Ignition lock cylinder
- Under hood light
- wiring, rats, and help!
- 69 Delta 88 issues
- Alternator light
- Is it possible to add intermittent wipers? '77 Delta 88
- 1990 Oldsmobile cutless ciera s electrical problems
- Printed circuit board gas gauge
- Primary Wire guage question(s)
- Date Correct Starter?
- 62 starfire tach wiring
- New Harness for my '68 442
- Problems starting my 442
- Blower Motor Pops Fuse on High Speed
- 1979 Custom Cruiser Wiper Problems
- Generator wiring thread - Reversed?
- Tune Up
- Modified AC system, valve or pressure sender
- Under hood wiring
- HowTo: 5.75" SAE headlight upgrade to Hella H1
- Please help wiring nightmare!!!
- Next Project; Get wipers to work
- Heater blower problem!
- Spark plug wire sizing
- 1968 olds clock repair
- Which Switched Hot to use for Stereo
- Why would they do that?
- Turn signals not working and when the ignitions in on, there's a buzzing sound
- Power Antennae
- conv switch wiring
- Has anyone replaced their distributor core with Cardone parts?
- Blower fan has power, will not work, 1977 Delta 88
- Digitails LED tail light kit
- Horn relay
- dash lights
- windshield wipers not working
- Dome light fuse keeps popping..as well as the radio fuse pops
- Battery Issues
- Rally Pack Wiring
- Gen light stays on
- 56 Ignition Coil Picture Needed
- TACH circuit board
- These wires need a home please HELP
- Rally Pack resistors on back of gauge cluster
- Electrical Shop in the Ft Worth TX Area
- Ignition switch
- Flasher Switch
- tic toc
- need help with wiring
- Alternator Wiring Issue 71' 98
- Turn Signal and Windshield Wiper Problem
- Rally pak question
- Correct ground hole on radiator core
- Reverse light and neutral Safety Switch
- Wipers, Part II
- Gauges not working
- Cruise control stick @67 A Body
- 71 vert electrical issues
- Help! Turn signal not cancelling correctly
- 1968 442 interior orange wire connector location
- Underhood Relays - 70 442
- Exchanging red/yellow side markers on a '70 Cutlass Supreme
