Battery Issues
Old Feb 23, 2014 | 05:14 PM
Oldracerjones's Avatar
Battery Issues
Tried to start today and had no battery voltage at all. No lights, sound, nothing. Drove it for an hour or more last weekend starting and stopping multiple times until I parked it in the garage. Tried it this morning, nothing.
No lights left on. The only things I did in the week was I pulled the center of the steering wheel since the horn wasn't working, saw no wires so put the cap back on. Also the channel change button on the eight track was pushed in. There were no lights on, interior lights out, doors shut, hood shut, trunk shut.
Maybe the battery just can't hold a charge anymore.
Anyone have any ideas for things to check?
Old Feb 23, 2014 | 05:34 PM
Chances are it may be a bad battery. With it running your charging voltage will be around 14.2-5.
Old Feb 23, 2014 | 11:52 PM
rustyroger's Avatar
'87 Delta 88 Royale
Just take the battery to your local parts store and have them check it out for you.
Roger.
Old Feb 24, 2014 | 03:45 AM
Grace Stinespring-Welch's Avatar
i agree with getting the battery checked. also clean all of your connections, and the grounds.
Old Feb 24, 2014 | 03:00 PM
Checked the car for parasitic loss and found none. Battery was charged today after sitting all night. Next step is to take it to the local Oreillys and have them check it.
Old Feb 26, 2014 | 10:06 AM
Well looks like it was the battery. Had it checked at the local parts store and it was no good. Purchased a new one, so far so good.
Old Feb 26, 2014 | 10:07 AM
It happens, do the voltage check with the engine running. Like I said it should in the 14.something range.
Old Feb 26, 2014 | 10:17 AM
Professur's Avatar
The local Walmart here has a fancy tester that runs the gauntlet, parasitic, battery, alt, etc. And they'll do it for free (here) in hopes of netting a battery sale. Gives you a pretty little printout to look over at your leisure as well.
Old Feb 26, 2014 | 01:26 PM
I brought my sons 2006 Mustang to Walmart when his battery went dead and it said that his alternator had bad diodes in it. It was wrong, as the alternator and regulator were charging correctly, so I cleaned the posts and hooked everything back up and still no issues after 6 months.
Old Feb 26, 2014 | 01:35 PM
63super88's Avatar
lucked out with just a battery. when I first got my olds I probably turned in a good battery thinking it was bad, was less than 3 years old (could've been bad, last guy probably ran it dead few times with faulty charging system). turns out the dirty wiring and bad regulator were the culprits, cleaned up wires and replaced regulator and runs like a champeen. the slight parasitic draw from the bad passenger side door jam light switch doesn't help but the car is fine now even after weeks of sitting still hooked up.
Texas442
Mar 28, 2013 07:13 PM
Dru
Feb 7, 2011 04:08 PM
w-30dreamin
Jan 9, 2010 03:19 PM
bermuda
May 18, 2006 11:38 AM
