'68 442 electric
Old Jun 16, 2014 | 12:43 PM
enginejet's Avatar
'68 442 electric
I just finished with an under hood restoration, engine, trans, radiator painted and cleaned. When I was doing all this though I removed some gauges the previous owner had installed. The underdash 3 Oil press, water temp, amps. I also removed the electric wires that ran to it too. Problem is that I didn't take photos or notes about these wires just thinking everything was just for the gauges. Now I don't have any power to anything. There is a wire that comes off the positive cable and I think it ran to the gauges. I think it should go to the horn relay but I'm not sure. I tried looking at the wire diagram on WAC's but it is not very clear even when printed. I've read through a number of other posts and wonder if someone could email me the wire diagram for a '68?
It would be very much appreciated, the motor and all looks great but what does it sound like??
Photos of the completed work coming..
Old Jun 16, 2014 | 01:13 PM
allyolds68's Avatar
PM me your email address and I'll send it to you
Old Jun 16, 2014 | 01:35 PM
The reason you have no power to anything is probably because you removed the amp gauge. Without it you would have needed to connect those 2 wires together.
Old Jun 17, 2014 | 09:05 AM
enginejet's Avatar
I hooked up the wire to the horn relay and all my electrics work now. Interestingly I now have interior lights when I have a door open. They didn't work when this wire was hooked to the amp gauge (not a factory gauge by the way). I haven't dug any deeper into the wire diagram I am just happy I can start the engine. A couple more quick items to get off the checklist and I should have it on the road by the weekend!
HonestDave
Jul 11, 2014 07:47 PM
442rocketdave
May 24, 2013 10:41 AM
bobfo1
Nov 25, 2012 10:37 PM
DRXOLDS
Jul 2, 2012 07:02 PM
kpl70sx
Jan 7, 2012 08:56 PM
