1967 oldsmobile
1967 oldsmobile
I have no power going to my electric windows. Where is the relay for the electric windows. I have heard it is behind the driver kick panel? The main pink wire from the fuse panel when hooked up makes a bonging sound when it is first hook up or when I turn the key swith. But no power to windows.. I have jumped a hot wire to the red/white wire and the front window work from the master switch.
Pass any info you can please.
Dean
Dean
relay on cutlass power window
Ok, Thanks for that info.. I have the kick panel loose, but to tight to get it out with the emergency brake in the way, any suggestion on that removal??
I will continue to try and remove the kickpanel, but may have to unbolt all of the backets for the emergency mech, unless there is a special way to remove the kickpanel because it is so deep/thick no room to bring it out
Dean
.Dean
Dean
.Dean
relay on 1967 oldsmobile
Found relay above heater duct going to front window for electric window supply. Replaced and windows work. Any one have a delete plate for the a/c area?
krobsklassics
May 12, 2009 08:33 PM
Kaline
Mar 22, 2008 08:26 PM
