Console lighting
Old Jul 17, 2014 | 02:42 PM
Redbud40's Avatar
Console lighting
Having an issue with the 3 lights well 1 of them. There are the shift indicator light. The rear floor courtesy light and the interior box light. Shift light works with headlamp switch ok. Rear floor light works with door open and rotation of headlamp switch. Ok. The prob is the interior box light.. I have three grounding wires. One is a clip end the other two are spade terminal ends..(similar to speaker connections). When I touch the two spade conn together the box light illuminates..(eventual bat drain). Or with one of them gnd light comes on however can't seem to find the combination for this light to come on when it is required. Is there a plunger switch for the console door that I am missing. Sinnce this console did not have the box in the first place don't have much to go on... Questions
1.what is the proper working order for the console box light?
2. Any suggestions for the grounding wires I have some control over but not what I need. Thanks
Old Jul 17, 2014 | 02:59 PM
oldspackrat's Avatar
There should be a plunger switch in the rear part of the console storage area. It has 2 male terminals that those female ends plug into. They are similar to the door plunger switches on some cars. I might have an extra switch or two, give me a call?
Scott
c. 317-727-7041
Old Jul 17, 2014 | 05:59 PM
Yeah, that plunger switch goes through the hole in the console inserts and housing, and the plunger contacts a raised, round area on the bottom of the console lid. Should be fairly obvious where the plunger mounts.
Lady72nRob71
Jul 1, 2012 09:56 PM
69OLDSCUTCONV
Jun 12, 2011 06:30 AM
MHENDERSON
Dec 8, 2010 05:28 AM
ctrain22
Dec 2, 2009 08:24 PM
aafuel
Jan 21, 2009 07:12 AM
