Console lighting
Old Jun 11, 2011 | 07:14 AM
69OLDSCUTCONV's Avatar
Console lighting
69 cutlass convertible, back courtesy lights look like ge 68 does that sound correct ? Anyone have other numbers. Also does anyone know the following bulbs for floor shift console non h/o shifter ? Shift indicator, front and back of console lights, and hinged box lighting.
Old Jun 11, 2011 | 05:35 PM
69442C's Avatar
The rear courtesy lights, assuming you are referring to the ones in the rear arm rest panels, are GE90. I can check on the other lights tomorrow and will let you know.
Brian
Old Jun 11, 2011 | 06:39 PM
starfire's Avatar
The armrest lights and front courtesy lights are 90.
Shift indicator and console compartment (hinged box) are 1895
Console courtesy lights (front & back) are 97
You should really buy yourself this:
http://cgi.ebay.com/ebaymotors/1969-...#ht_1268wt_722
Old Jun 12, 2011 | 06:30 AM
69442C's Avatar
[quote=starfire;290072]The armrest lights and front courtesy lights are 90.
Console courtesy lights (front & back) are 97/quote]
X2 on the shift indictor and console lights but double check the front under dash courtesy light sockets before buying a 90 bulb for them. The 90 is called for in the Chassis Service Manual for these lights but the reproduction courtesty light sockets that came with the reproduction harness I purchased only had a single contact in the socket. Since 90 bults have 2 contacts on the base of the bulb, they didn't work. As a result, I needed to use a 67 bulb for the front courtesy lights.
Redbud40
Jul 17, 2014 05:59 PM
Lady72nRob71
Jul 1, 2012 09:56 PM
MHENDERSON
Dec 8, 2010 05:28 AM
ctrain22
Dec 2, 2009 08:24 PM
aafuel
Jan 21, 2009 07:12 AM
