'67 442 Trunk Wiring Help
Alright, I know I took pictures, but cannot seem to find them. I need help with the wiring the runs under the pass side carpet up to the trunk divider.
1 Speaker wire
1 Power antenna harness
1 Antenna cable
I am good all the way to the trunk divider, but I cannot seem to make sense on how the wires are routed from there.
I was wondering if someone is able to send a picture of this area from the trunk to let me see how I should route these wires.
Any help will be greatly appreciated.
-Jeff Sims
1 Speaker wire
1 Antenna cable
-Jeff Sims
No sir. The ribbon cable is under the driver side. The antenna, rear speaker and power antenna wires are ran under the pass seat. Right where these three meet the trunk divider, the antenna cables split toward side while the speaker wire runs up to the speaker. My problem is that I do not know the exact path from the trunk divider to their connection points. When I get home today, I will take pictures of what I have.
I imagine the 66 I have and your 67 would be the same, but mine doesn't have a power antenna, and, of course, years ago, I put in 4 speakers an amp and a different radio, so I really can't remember. I do recognize the orange and white wires going between the courtesy lights. Sorry.
shamusj
Apr 7, 2018 08:10 AM
oldzy
Sep 10, 2009 05:23 AM
