1968 A Body Courtesy Harness Connections
Old May 25, 2014 | 08:11 PM
Tom442's Avatar
From old posts, I gather the passenger side jamb switch has two wires? Apparently my passenger side had been changed out to a single connection switch. I thought I had all my connections labeled.
According to the wiring diagram, my unmarked white wire is supposed to go to the jamb switch? It runs along the orange wire that goes to the glove box switch/light assembly.
Old May 26, 2014 | 02:12 AM
Yellowstatue's Avatar
The driver side has two white wires on two terminals (one wire is for the key buzzer) and the pass. side has one wire on one terminal...so there are two different switches.
Old May 26, 2014 | 08:56 PM
Tom442's Avatar
Awesome, thank you. The passenger door jamb switch white wire is already connected as part of the under dash courtesy harness.
So where does this white wire with the cheap crimp on bullet connector go?
Old May 27, 2014 | 03:25 AM
Good question; I'll have to go and look at one of the cars to see what's up. Is that orange wire, factory taped to the white one.
Old May 27, 2014 | 07:04 AM
Tom442's Avatar
Yes, the orange wire that is the glovebox switch/light bulb, is taped to the white wire in question. It is long enough to reach the passenger door jamb switch. It is not the underdash courtesy light harness.
scott_442
Aug 19, 2014 05:29 PM
1978 Oldsmobile Omega
Aug 10, 2014 07:03 PM
442mark
Jun 14, 2014 08:41 PM
Tom442
Jul 31, 2013 06:48 PM
Tom442
Sep 4, 2012 02:14 PM
