Please help. Blower fan won't turn off.
Old Apr 25, 2014 | 03:31 AM
5998DownUnder's Avatar
Hi there,
I have a 1959 98 Olds Holiday Sceni-coupe.
When I turn the ignition on, the heater fan runs even when the heater fan is in the 'OFF' position.
I have replaced the heater control resistor.
I have now replaced the heater sensing unit.
I cannot see in the manual anything else to do with this problem.
Help appreciated.
John.
Old Jun 21, 2014 | 02:58 PM
mojonitro's Avatar
Jim R
Have you checked to see if there's voltage on both sides of the on off switch in all positions? You may have a bad switch ( there should be no continuity through the switch when off), and voltage is getting through. The other thing may be a bad ground letting voltage get back to the circuit.
Jim
Old Jun 21, 2014 | 05:03 PM
Hi there Jim.
I will check that out.
Very nice car too by the way.
John.
Old May 8, 2016 | 05:59 PM
rd3cafe's Avatar
1959 olds heaterblower on
hi can anyone help ,we have encounted the same problem as you .our heater blower runs all the time . the vacume on/off masterswitch is ok. but we have power to both sides of the switch?has anyone solved this issue and what was the cause? thanks brad
Old May 8, 2016 | 07:36 PM
If the switch is in the off position and you have voltage at both sides the switch is bad. Disconnect one side and see if the fan turns off.
Old May 8, 2016 | 08:53 PM
Hi there,
By 'switch', do you mean the switch on the dash to control the heater fan or the switch on top of the heater blower under the bonnet?
John.
Old May 9, 2016 | 01:51 AM
rd3cafe's Avatar
heatewr blower
hi ,thanks for your replys ,the switch i'm referring to is under the bonnet by the blower ,if i disconnect both wires from the switch,each one has power to it? thanks brad
H8D-67
Sep 16, 2013 01:19 AM
BradyB
Sep 12, 2012 10:05 AM
dennisspeaks
Sep 24, 2011 01:10 PM
dr.chaos
Mar 15, 2011 03:37 PM
miho35o
Nov 7, 2008 08:22 AM
