1952 Starfire blinker issue
1957 Starfire blinker issue
Hello;
I have an intermittent blinker issue usually with my left blinker and seldom with the right. I will flick the leaver to turn left and the indicator will flicker and the nothing after that. If I return the blinker to centre and back to the left it 9 out 10 times will work. Is this possibly an adjustment in the column or a relay issue?
Mark
Mark
Last edited by Mark57; Aug 2, 2014 at 08:36 AM. Reason: edit title from 52 to 57 …wrong vehicle
Is it possible if one of the lamp sockets isn't grounded proper that this can happen?
Mark
It could also be grease or corrosion on the contacts in the switch unit. This is easy to fix, but you will have to pull the steering wheel to check.
Try cleaning the contacts, and then lube them with a small amount of dielectric grease. Test the operation before you put the wheel back on.
Mark
