Blinker Issue
Old May 15th, 2011, 09:16 PM
kona0197's Avatar
Blinker Issue
So I bought a 1990 Cutlass Ciera. When turning left the blinker works fine. However when turning right the light stays on and will not blink. What part needs replaced?
kona0197 is offline
Old May 15th, 2011, 10:33 PM
Big Blue 72's Avatar
I's start by checking the flasher relay and the bulb. Otherwise there could be a wiring issue elsewhere.
Big Blue 72 is offline
Old May 15th, 2011, 10:39 PM
kona0197's Avatar
Flasher relay down in the circuit breakers? One for each side?
kona0197 is offline
Old May 16th, 2011, 03:04 AM
In a modern car or an older German car, the signal lights not blinking on one side only usually means you've got a light bulb out.
Fewer bulbs = less current = can't heat up the flasher enough to bend the bimetallic strip to open the circuit = lights stay on and don't blink.
Handy and simple warning mechanism.
MDchanic is online now
Old May 16th, 2011, 07:04 AM
kona0197's Avatar
No lights out - they all light up. But if I recall correctly the blinker lights have 2 bulbs inside right?
kona0197 is offline
Old May 16th, 2011, 07:10 AM
2 filaments, yes.
The dim one lights with the parking lights, the bright one with the signals or brakes.
If there is a ground problem, or if one bulb is screwed in wrong, you can get weird problems like this. When you turn on the signals, do both lights on that side glow bright, or is one dim? What happens if you step on the brake with the signals on or off?
Old May 16th, 2011, 02:15 PM
kona0197's Avatar
I will check that as soon as I can. Anyone have a clue how to change these bulbs out?
kona0197 is offline
Old May 17th, 2011, 03:10 PM
kona0197's Avatar
Turns out the rear blinker was dead. I replaced the bulb and all is well. Now how do I remove the stock radio? Is there a video for this?
kona0197 is offline
Mark57
August 3rd, 2014 05:53 AM
oldsowner1977
April 6th, 2009 12:36 PM
smcurro
March 28th, 2009 07:36 PM
Satellitecentral
August 30th, 2008 09:04 AM
sickbox
November 20th, 2007 03:56 AM
Quick Reply: Blinker Issue
