wiper motor wiring picture?
Old Jul 31, 2014 | 06:16 AM
tbristol's Avatar
Hello, does anyone have a picture of the connections on their wiper motor with washer pump on a 70 cutlass convertible with factory air and 350?
I installed a new to me used motor. It worked for 15 seconds then the magic smoke escaped. I couldn't catch the smoke. So now the motor doesn't work. After studying the CSM My color wires do not match the wires I have. I was wondering if anyone has a picture or can take a picture of the two plug wire up top and the three wire plug on the middle. I'm pretty sure I plugged the connectors in the same way I unplugged them. That may not be the case though.
right now I have the top two prong connector with a yellow and green wire I have it plugged in with the yellow wire facing the drivers side. the bottom connectors has a single plug that is green I have plugged in closest to the drivers side. then a two prong connector with a yellow and black wire. I have it plugged in with the yellow wire next to the green wire. Can anyone confirm?
Sampson
Aug 17, 2014 05:57 PM
66-3X2 442
Feb 25, 2014 07:19 PM
hotrod
Oct 9, 2012 02:26 PM
Custom68
May 22, 2012 01:50 PM
Flye
Mar 28, 2009 05:40 PM
