Power master starter
Bout to hook up my power master starter in my 68 olds 442, motor has been out of the car for a while so I'm trying to remember what wires go where?
I know where the battery cable goes but there is purple wire 10 gauge or so and a yellow wire maybe 16 gauge or so.
I have the R terminal diode kit from power master and the instructions say to splice/crimp it to the R terminal wire from the vehicle.
Is the vehicle R terminal wire the smaller gauge yellow wire? I think it is but I just wanna be sure.
I just had the powermaster 9610 installed in my 76 350, it works great fires up instantly, Oldcutlass gave me the suggestion.... happy I purchased one now, threw me off at first, it just sounds different from the original. I like the weight difference as well.
I have a Powermaster mini starter and I love it, but I use a remote relay to power it and supply power to the distributor on startup. I don't trust the diodes. You need to make sure the starter to flex plate gear gaps are correct.
eddieunderground
Brakes/Hydraulic Systems
Nov 26, 2010 09:46 PM
69convertible
Dec 7, 2008 02:03 PM
