Passenger Side High Beam not woking wiring
Old Jun 9, 2014 | 04:23 PM
68cutlassconv's Avatar
Cool Passenger Side High Beam not woking wiring
There seems to be a loose wire - high beam not working on passenger side. Replaced bulb, but still not working - seems to be a ground wire hanging on the other side by the lights. Is there a diagram for wiring of passenger side high beam or any ideas as to how to get same to work.
Old Jun 9, 2014 | 04:24 PM
sorry first post - issue with high beam is on 1968 cutlass s convertible (one owner car)
Old Jun 9, 2014 | 04:32 PM
allyolds68's Avatar
Yes the lighting harness has a dedicated ground wire but that probably isn't why it's not working. Is it the original harness? 68 light harnesses have a issue with burning up at the body connector location.
I have a 68 wiring diagram I can e-mail you if you PM me your email address
Old Jun 9, 2014 | 04:34 PM
Since the passenger side is connected off the drivers side it should not be very difficult to figure out. follow the wire hanging back to the source and see if its indeed your lighting ground. If so, connect it. I have had new bulbs out of the box be bad also.
Old Jun 9, 2014 | 04:37 PM
Yeah, there's not much to this - Three wires: High, Low, and Ground, and only the High and Ground go to the high beam bulb.
They run across the core support to the driver's side headlights.
Just use a test light and follow along to see where the connection goes away.
Old Jun 9, 2014 | 10:04 PM
RandyS's Avatar
And the ground (black) wire on both sides need to be securely grounded.
woody30
Tech Editor's Desk
Sep 15, 2012 08:45 AM
ramair
Jul 15, 2011 01:14 PM
scott71
Jun 18, 2011 07:04 PM
kandelino
Nov 5, 2010 06:45 AM
BaileyJD1
May 1, 2008 11:45 AM
