Tail light question
I finally located the thread I mentioned above:
https://classicoldsmobile.com/forums...storation.html
You basically can't remove the socket without damaging it because it's roll pressed into place when it was built. There are also 2 small springs in the bottom of the socket that push up on the contacts for the light bulb. Need more information on what's 'broken'.
I restored the buckets and connectors on my 72, but the sockets weren't in terrible shape. The sockets on a 70 are much easier to work on because of the way the bucket line up vertically.
You can use components like this to replace faulty connectors.
jensenracing77
Dec 11, 2013 08:22 AM
