Headlight Relay Help Needed
Old Jun 23, 2014 | 05:47 PM
starfire's Avatar
OK, I got a headlight relay kit for my '68 Cutlass (four headlight system), installed it according to the directions, and it works perfectly. I love it.
So I bought a headlight relay kit for my '78 Starfire (four headlight system). Bought it from a different outfit. I installed it according to the directions, and it works, but the bright lights are on when the bright light indicator is off, and when I click the dimmer switch the bright light indicator comes on, and the bright lights go off. I unhooked the relay system and plugged the stock harness back in and everything works like it should. Am I missing something simple here before I call the company and complain? The lights cannot be plugged in backwards as the outer lights are three prong and the inner lights are two prong. Any ideas?
Old Jun 23, 2014 | 06:45 PM
Apparently something is backwards in your relay wiring.
Old Jun 23, 2014 | 06:54 PM
"Kit?"
What's wrong with buying two $4 relays and connecting it yourself, so you know that it's done right?
We would need to see detailed photos of every part of the kit to be able to know what's going on.
Old Jun 23, 2014 | 08:05 PM
starfire's Avatar
Originally Posted by MDchanic
"Kit?"
'Cause sometimes I's just lazy. Looks like I'll call them tomorrow and ask them "What's up with that?".
I figured, based on my track record, that I was just missing something really simple.
Old Jun 23, 2014 | 09:54 PM
Silly question, but why do you need a relay for the headlights?
Old Jun 24, 2014 | 08:09 AM
starfire's Avatar
Not a matter of need Joe, it's a matter of I don't ever want to go under one of those dashboards again if I can help it. I'd rather replace relays under the hood once a year than have to remove either of those headlight switches again.
Old Jun 24, 2014 | 09:40 AM
Octania's Avatar
Sounds like your high beam lamps are fed from the lo beam relay and vice versa.
Assuming there are two relays and not one SPDT used for either lo or high energizing.
Old Jun 24, 2014 | 11:34 AM
starfire's Avatar
Yes, there are two relays.
Old Jun 24, 2014 | 02:57 PM
pcard's Avatar
70 Cutlass SX
You could have normally closed relays rather than normally open, or wired the output to the 87a terminal rather than the 87 terminal.
Old Jun 24, 2014 | 08:17 PM
starfire's Avatar
Peter, that could be the problem, but the relays came prewired and are supposed to be correct. I tried calling them in Cali today, but got an answering machine. Not a good start customer service-wise. I left my number for them to call me back, but as of 8:00 pm EDT (5:00 pm PDT which they list as their closing hour) I still don't have a call back. I'm calling them again tomorrow at 1:00 pm EDT.
pcard
May 14, 2014 01:21 PM
70ToroGT
Aug 19, 2011 09:38 AM
cessna195
Feb 22, 2011 10:59 AM
Beob
Feb 11, 2011 06:38 AM
1973olds98
Apr 12, 2010 08:01 PM
