PDA
View Full Version : Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25
  1. Aftermarket radio loses "memory" when cranking
  2. Looking for a '75 Delta 88 Royale power antenna
  3. Battery Wiring Photo Needed 69 442
  4. Wiring harness 57
  5. Underhood Light - how to dismantle/ replace wire?
  6. 71 Cutlass gen and oil light stays on with ignition off
  7. gas tank sending unit and guage
  8. Installed RestroSound Model 2 Malibu in 68 Delta 88
  9. Radio conversion for 57
  10. 68 cutlass parking lamp issues
  11. What sparkplugs to use with MSD ignition or HEI?
  12. 1969 442 - Lost Dash Lights and Wipers Won't Stop
  13. Auxiliary Gauges/Tach Illumination When Brake Pedal Pressed.
  14. What is this old style disturbutor Worth?
  15. Heat. ONLY Heat.
  16. what causes a voltage regulator to stick?
  17. Radio conversion
  18. New CS130 Alternator Humming
  19. spark plugs gap
  20. vacuum advance
  21. Disconnecting the circuit test for coolant temp idiot light
  22. Baffling battery buying...
  23. Fuel Gauge Problem
  24. Best ignition for my 1966 Dynamic 88?
  25. Lost the dash lights 85 delta
  26. blower control wires melting
  27. 1968 Ign switch question
  28. Weird starting, electrical fault
  29. F150 electrical mess (long)
  30. Brake light
  31. dome lamp connector 70 olds 442
  32. WTF Happened to my battery??
  33. 1965 98 power antenna
  34. 77 Cutlass oil pressure light issue...
  35. 1-Speed Blower Motor
  36. 1972 cutlass taillights wireing
  37. Wiring help needed on 1966 Cutlass
  38. damsel in distress
  39. Can someone with knowledge in early 80's Delta 88's give some guidance?
  40. 69 dash harness
  41. Hood courtesy light
  42. Universal code reader?
  43. air conditoning question
  44. On/Off switch for key buzzer
  45. Electrical
  46. Accel 300+
  47. Cutlas Alternator
  48. 83 H/O Voltmeter
  49. 55 Olds dash lights and horn not working
  50. Fan switch
  51. 1972 Starter Brace
  52. I need a fuel tank sending unit
  53. Wiring Harness
  54. lo amp 1 wire alternator for 68-72
  55. Testing Alternator and Battery
  56. HEI Questions and Info
  57. Electronic distributor for 55 rocket 88
  58. good reproduction battery
  59. Alternator voltage?
  60. Alternator? ..and a funny story
  61. wiring harness
  62. 68 rally pac fuel gauge working backwards
  63. 72 Supreme headlights
  64. 1972 Supreme High Beam Indicator
  65. No Power to Convertible Top Switch
  66. Back-up lights
  67. Head Light Question
  68. fuel needle pinned beyond full
  69. Starter wires
  70. Radio and turn signal issues...
  71. Alternator up grade
  72. 10 OHM speakers?
  73. Ignition Switch for Tilt Column
  74. EL Opera Lighting
  75. Any advantages to a MSD box?
  76. Add a power passenger seat to an Oldsmobile Custom Cruiser
  77. Replace power antenna on Custom Cruiser
  78. 67 442 Fuse Block
  79. Power Window Motor Question ???? (72 Cutlass)
  80. '66 E body wiring diagram (toronado)
  81. 71 Cutlass wont shut off
  82. turn signal problems....
  83. Wiring diagram for Delco AM Radio No: 7935003 23APB2
  84. Bad Headlight Switch?
  85. Car Totally Dead
  86. 1955 98 wiring help
  87. '70 442 Front Lenses (Turn Signal)
  88. Turn Signal Switch - 1968
  89. Guages
  90. 1976 Delta 88 Turn Signal Flasher Part number?
  91. Headlight problem
  92. 1967 442 I P Ground Wire
  93. reset knob on clock
  94. Rally Pack and HEI
  95. Dash wiring and door jam switch
  96. Cruise Control Wiring Diagram
  97. Another HEI question
  98. 1964 Cutlass Flickering Generator Lights Ignition Problem
  99. Power Distribution Block Location
  100. 67 442 headlight harness clips
  101. HEI distributor too good to be true?
  102. Ported Vacuum Switch - Testing?
  103. GEN light on when car turned off
  104. Fuel sending unit for 56 Olds
  105. 81-87 Tail lights
  106. Turn Signals don't work, Hazard's Work, Generator Light on at start up
  107. rear window defogger
  108. 67 Delta 88 blower motor resistor
  109. Power Antenna Noise Through Radio
  110. stereo amp pin-out
  111. Stock starter not running HEI
  112. Fuse Block
  113. big 3 upgrade
  114. Hard to get ignition switch to start postion
  115. Gas guage issue
  116. Where is the door jamb switch located on the 1992 Oldsmobile Toronado
  117. No instrument lights? cutlass 1968
  118. alternator plug wires
  119. Harness and WW
  120. Clutch Safety Switch
  121. 1968 442 AC removal…what electric can I delete?
  122. Under dash wire harnesses
  123. Odd turning signal problem
  124. Problem and question
  125. Headlite trouble on my 57
  126. 10 ohm resistor wire - bulk head to acc terminal
  127. do i have too change anything when converting to 12vlt for stock tac
  128. Differences between 68 Z cars & all others
  129. Dim GEN light
  130. 68 442 power windows slooooow
  131. Cruise Dash Switch Light Bulb
  132. RETROSOUND Radio rip off!!
  133. 1965 (66?) 88, 98 series (all big cars) Horn relay replacement solution!
  134. 86 Cutlass electrical problems (PLEASE HELP)
  135. dynamic 88 fuel gauge
  136. Ignition lock bezel
  137. Help with Cutlass sending units
  138. No fire!
  139. Help with wires in stock AM radio
  140. What is it?
  141. wire harness preferences
  142. 67 442 headlight question
  143. Top post battery cable ends
  144. 1988 oldsmobile cutlass supreme classic
  145. Rear Defogger Wiring Help Needed
  146. 69 Cutlass turn signal
  147. 1970 Cutlass Front & Rear Bumper Electrical
  148. cutlass -68, wiring diagram for headlights?
  149. '70 442 Correct Color/Gauge Wire
  150. Generator to CS alternator conversion wiring
  151. How should headlights/markers/dash lamps work correctly?
  152. 72 cutlass tail light and instrument light issues
  153. Radio wiring question
  154. turn signal not blinking, 72 cutlass
  155. wiring diagram 72 cutlass supreme
  156. Alternator replace or rebuild?
  157. 72 cutlass Re-wire
  158. 64-F-85 steering column issue-horn pin needed
  159. American autowire wiring harness kit, Highway22
  160. 69 Cutlass: how to remove dash gauges?
  161. 69 Cutlass: how to remove headlight switch?
  162. 69 Cultass S Wiper wiring redo
  163. How to change ignition switch
  164. Fusible link cooked
  165. New Starter has no power....help needed
  166. LED Turn signal bulbs fit
  167. Console harness
  168. 71 Cutlass vert switch
  169. Speakers for a Stock AM/FM Oldsmobile Stereo?
  170. '70 442 Washer Pump Replacement
  171. Correct tail lights socket (1969 Supreme)
  172. Internal vs external regulation
  173. Washer pump
  174. Gen Light On - Where does this go?
  175. '70 442 Ignition Switch
  176. Harness restoration, terminal suppliers?
  177. Leaking heater core question
  178. Sensor identification!
  179. Battery possibly not charging
  180. Cig Lighter and iPod Charger
  181. Turning signal socket
  182. 67 Cutlass A/C-Heater Wiring
  183. Fuel Gauge Wiring
  184. ventilation setting problems
  185. 1969 Factory Tach
  186. Blower relay!
  187. In need of heating and cooling help!!!
  188. lost keys
  189. Sport Steering Wheel - Horn Help
  190. Nav lights not flashing
  191. internally regulated alt question
  192. 1966 98 Headlight Switch Connection gap
  193. fuel gauge ohms
  194. 72 Cutlass pwr window/lock question
  195. location of 79 cutlass horn relay
  196. Upgrade from idiot lights to electric gauge. Little help...
  197. Starter solenoid wire
  198. Best repop wire harness?
  199. Stock Wires with Pertronix Ignitor II
  200. Stock Tachometer acting funny
  201. Tail lights and side markers won't stay on and keep blowing the fuse.
  202. Halogen headlight conversion
  203. External Regulator
  204. Door Panel Speaker Size
  205. battery drain from courtesy lamp circuit
  206. AMP Light Issue 1970 Oldsmobile Delta 88
  207. Voltage regulator buzzin
  208. 67 tic toc tac
  209. wont start can jump starter
  210. Turn Signal not working left side 72 cutlass
  211. what da hell is dis?
  212. Courtesy light mystery
  213. electrical issues....where to start
  214. To use the old wire harness or not?
  215. Alternator not charging
  216. 1984 Cruise Control
  217. No spark 1962 Super 88
  218. 72 cs dome roof light
  219. how can my tac be wired to procomp distributor
  220. 1969 dash wiring
  221. Convertible Top Switch Issue
  222. interior lights ,dome dash etc....wont work
  223. Hei conversion problems
  224. Speakers
  225. Replacing mech distributor with HEI
  226. Gauge Wiring
  227. '70 442 Steering Assembly
  228. Distributor Rotor Gap
  229. Junction box
  230. Help with 6 volt system - 1948
  231. dwell on a 61 f85 215ci v8
  232. Headlamp/radio issue
  233. Directional Signal Fuse issue
  234. Turn signal switch
  235. E Z wiring
  236. 64 dash clock
  237. 72 Cutlass Dash Wiring
  238. I think I may have just killed the wiper motor?
  239. car won't start and battery won't charge
  240. Wiring harness connections
  241. Mystery battery drain
  242. Warning Buzzer to Tone module upgrade
  243. Harness Replacement
  244. Wiper motor/wiring disconnect
  245. People amaze me
  246. 71' Cutlass wiper motor can color
  247. Alternator and Battery new 1987 oldsmobile please help!
  248. lights flickering... on to the next problem...
  249. generator and voltage regulator questions please help!
  250. 1965 cutlass
