Go Back  ClassicOldsmobile.com > Repair & Restoration > Electrical
71 Cutlass gen and oil light stays on with ignition off >
Old April 10th, 2015, 12:14 PM
N2ROW's Avatar
My gen and oil light stays on when I shut off the car. When I remove the wire from the oil sending unit it does go off. The gen light stays on even with the wire off the gen. When I start the car all the lights functions properly. I replaced the ignition and head light swith no change. tonight im replacing the turn signal switch, but I dont think it will effect it since I disconnect the harness trying to find out why those lights stay on with ignition off. 71 cutlass convertable
N2ROW is offline
Old April 10th, 2015, 12:27 PM
Your back feeding power through the system somehow. When did this problem start?
oldcutlass is online now
Old April 10th, 2015, 12:36 PM
N2ROW's Avatar
about a month after I replace the guage. All worked fine untill one night I went into the garage to do some work on the car and noticed the lights on.
N2ROW is offline
Old April 10th, 2015, 12:42 PM
Which gauge?
Old April 10th, 2015, 12:47 PM
N2ROW's Avatar
Sorry the Fuel guage which includes the idiot lights, GEn, oil, hot etc.
N2ROW is offline
Old April 10th, 2015, 12:55 PM
N2ROW's Avatar
guage I installed
N2ROW is offline
Old April 10th, 2015, 01:27 PM
Your going to have to go back through your wiring you have battery power supplying the idiot lights instead of switched.
Old April 10th, 2015, 02:02 PM
N2ROW's Avatar
ok will do. Thanks
N2ROW is offline
Old April 10th, 2015, 02:06 PM
By the way the gauges are cool.
Old April 10th, 2015, 02:35 PM
N2ROW's Avatar
Thank you.
N2ROW is offline
Old April 11th, 2015, 09:59 AM
N2ROW's Avatar
You was right. I found a hot wire tied in to the power lead to the convertable wire. That wire went into the acc in the fuse box. Condition corrected. Thanks
N2ROW is offline
Old April 11th, 2015, 10:04 AM
Glad you found it easily.
SouthCarolinaCutlass
December 31st, 2014 07:33 AM
rhett838
February 28th, 2014 08:25 PM
59Olds98
December 25th, 2013 08:20 AM
iabc205
February 20th, 2013 02:32 PM
night_tigeronthehunt
September 27th, 2009 04:46 PM
Quick Reply: 71 Cutlass gen and oil light stays on with ignition off
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
