Cutlas Alternator
Cutlas Alternator
What does the non-threaded post at the end of the pen do? It is loose but Auto Zone tested it okay. Can I just put a new grommet in it?Alternator.jpg
I don't know what that post is for but is that the alternator you are going to use?
The battery terminal insulation is melted pretty bad which means that it is loose and that is causing a bad connection at the rectifier and generating a lot of heat.
Get a anther alternator, if you use this one you are looking for trouble.
Joe
Joe
Joe
Joe
442mark
Sep 30, 2017 01:06 PM
