big 3 upgrade
Old Dec 7, 2014 | 02:09 PM
dillard.eric1987's Avatar
big 3 upgrade
I have an 1981 oldsmobile delta 88 i would like to know if anybody done the big 3 upgrade. to there delta, i would like to see some pics, and tips for good ground, and an good spot in the trunk thanks
Old Dec 15, 2014 | 07:04 PM
Any help?
Old Dec 15, 2014 | 08:31 PM
RetroRanger's Avatar
72 Olds CS
ok ill bite whats the big 3 upgrade ?
Old Dec 15, 2014 | 08:52 PM
oldspackrat's Avatar
I found this.
Performing a "Big 3" upgrade on your vehicle is one way to improve the electrical system performance and its ability to supply power to your audio system. This upgrade will help any vehicle using an after-market amplified stereo system, and most certainly should be performed on any vehicle after a high-output alternator is installed.
Please be sure you read and understand this entire instruction before you begin.
Definition: the "Big Three" upgrade means improving the current capacity of three cables: 1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis. Some people replace the factory wiring; others add additional cables to the factory wiring. This instruction is to add cables to existing OEM wiring
Old Dec 18, 2014 | 12:48 PM
cjsdad's Avatar
That needs to be "big 4"! I did that a few times when I worked as a stereo installer.
1. If you have upgraded to a higher output alternator you can add an 8 guage alternator-to-battery wire.
2. A 4 guage wire between battery and engine is good.
3. A 4 guage from engine to chassis,
4. and 4 guage from engine to body completes the upgrade.
You need a relatively high-end system to gain any benefit from these upgrades, but it sure won't hurt.
nj_cutlass72
Aug 10, 2011 10:28 PM
Kidcutty
Mar 10, 2010 06:08 AM
LMHConcepts
Jan 4, 2008 12:55 PM
bcg88
Jul 15, 2007 06:06 PM
sean000
Dec 22, 2006 06:41 PM
