Gas guage issue
Old Dec 6, 2014 | 12:20 PM
over my head's Avatar
Gas guage issue
Can anyone please help me figure out why my gas guage is like this? The needle won't move and seems to fall way to the right side and it's stuck there, is it a wiring issue or will I have to replace the guage? If it's fixable does anyone have a diagram or something to give me a hand? I really appreciate it!
Old Dec 6, 2014 | 01:09 PM
There are tons of threads on fuel gauge issues if you do a search. Basically it's probably your sending unit in the tank. If you remove the wire from the tank and ground it with the key on. The needle will go to E, that means everything else is good.
Old Dec 6, 2014 | 01:52 PM
Octania's Avatar
Ah yes the "Hot Fuel" issue
At first it looked like your "710" light lettering was backwards, but the issue was that the photo appears on my screen rotated 90 degrees.
Old Dec 7, 2014 | 08:43 PM
Mine does that occasionally. I think the sending unit wire where it attaches to the sending unit terminal on top of the tank is loose. I can wiggle the wire behind the license plate and it starts working correctly again. I'm just too lazy to drop the tank and tighten the connector.
edit: I should have mentioned I also had this issue on my '70 Supreme. I wasn't so lazy back then, so I dropped the tank and that is when I discovered the sending unit was fine and it was just a loose wire. It's a push-on style connector that goes onto a threaded stud, so I just used some pliers to crush the connector slightly and it was MUCH tighter when I pushed it back onto the stud. The gauge worked correctly for the next 10 years or so until I got rid of the car.
Old Dec 8, 2014 | 05:50 PM
kbass72's Avatar
Mine was like that when i bought my 70 cutlass, i was told it was most likely a bad sending unit. Put in a new sending unit and works fine now.
Old Dec 8, 2014 | 06:22 PM
Macadoo's Avatar
Looks like I'll be jiggling some wires this weekend
Old Dec 8, 2014 | 06:37 PM
jaunty75's Avatar
You have an open circuit. It could be in the wire between the dash gauge and the sending unit. It could be a bad connection between the sending unit and ground. If both are OK, it's likely the sending unit itself.
Your gauge pointing well past the Full mark is actually very consistent with an open circuit. The gauge is just an Ohm meter, and the sending unit reads anywhere from zero Ohms (Empty) to 90 Ohms (Full). An open circuit is infinite resistance, which is much higher than 90 Ohms resistance, so the needle moves well past the F mark.
Finn5033
Apr 10, 2012 09:23 AM
lmarquette
Mar 6, 2012 03:10 PM
Wtibbals
May 1, 2011 09:14 AM
parkerolds64
Oct 14, 2010 12:51 PM
joeolds
Sep 10, 2010 09:40 AM
