air conditoning question
Old Mar 8, 2015 | 03:56 PM
71oldsS's Avatar
I recently removed the air conditioning system from my 71 Cutlass and want to know if I need to change the resistor pack to operate the fan for a non-air car or am I ok with existing resistor. Thanks in advance for any replies.
Old Mar 8, 2015 | 04:03 PM
No need to change it, and nothing else you could change it to if you wanted to.
Leave the resistor pack as is. It has nothing to do with the A/C it is for the fan speeds on the blower.
Old Mar 9, 2015 | 07:31 AM
Keep in mind that unless you are completely converting to a factory heater-only configuration, you need to retain EVERYTHING from the A/C setup if you want to keep heat and defrost. That means that you must retain the resistor, blower motor relay, vacuum hoses, etc. You can remove the A/C compressor, evaporator, condenser, and associated plumbing, but everything else is required for heat/defrost function.
WTony
Feb 20, 2012 02:05 PM
jimjr
Jan 28, 2011 07:23 AM
cormike
Aurora
Jan 4, 2009 07:30 AM
Viper
Aug 13, 2008 10:58 AM
bjtstarfire
Jan 19, 2008 03:55 AM
