how can my tac be wired to procomp distributor
Old Aug 25, 2014 | 02:22 PM
steve walker's Avatar
swat455
hi how can this be done its a procomp 7000 2wire hei distributor to my fact tac 66 olds starfire
Old Aug 25, 2014 | 05:49 PM
There are 2 connections on large cap hei's, 1 is for power (Batt), the other is the for your tach.
Old Aug 25, 2014 | 05:55 PM
I don't know what a "two wire HEI" is. All GM HEI distributors have a three wire connector that runs from the module in the distributor body to the cap, then a single power wire labeled "BAT" on the cap. There is also a terminal labeled "TACH" next to the BAT terminal, which is where you connect the wire from the tach that previously went to the coil.
Old Aug 25, 2014 | 06:20 PM
swat455
hi its a speedmaster procomp 7000 small cap 2 wire distributer .so no tac slot . should of got a large dist but was worried about ac evap box hitting it at firewall..
Old Aug 26, 2014 | 06:48 AM
From what I can see on the web, the Procomp 7000 series is NOT an "HEI", which is GM's proprietary name for the coil-in-cap distributor design. This is where correct terminology would help you get a better answer sooner. The 7000 is simply an electronic trigger distributor that uses an external coil. It's frankly no different than putting a Pertronix unit in your stock distributor. Since you have an external coil, the tach should just hook up to the negative terminal of the coil, just like it would on any point-style ignition system.
Old Aug 26, 2014 | 07:19 AM
swat455
thank you
antweave
Mar 6, 2014 08:56 AM
garyfoust
Nov 25, 2012 04:32 PM
joepenoso
Aug 4, 2012 12:58 PM
RAMBOW
Oct 6, 2011 11:49 AM
ctrain22
Jun 8, 2009 10:17 AM
