71 Cutlass wont shut off
Old Jan 28, 2015 | 10:46 AM
N2ROW's Avatar
71 Cutlass Im able to start the car but when I put the key to the off position it wont shut off. Other things I notice. The oil light was on when in the off position. Car has tilt steering orignial unrestored. Any guesses were to start replacing parts.
Old Jan 28, 2015 | 10:55 AM
65JS1's Avatar
Sounds like a bad ignition switch to me. Possibly the linkage between the lock cylinder and switch.
Old Jan 28, 2015 | 11:41 AM
N2ROW's Avatar
So that would be on the bottom of the steering wheel were the harness for the ignition switch connectors are located?
Old Jan 28, 2015 | 11:50 AM
+1.
Could be. You can check both by getting to the switch.
Top of the column, above the pedals, yup.
You have to drop the column from the dashboard to gain access, but it's not a big deal.
Old Jan 28, 2015 | 12:06 PM
N2ROW's Avatar
OKay. So you recommend to replace ignition switch with key ad while in the colum ill clean any contacts as well as the igniton switch connectors. Is there any hardware between ignition lock and the ignition switch connectors?
Old Jan 28, 2015 | 04:11 PM
65JS1's Avatar
I would just start with the ignition switch. The switch is actuated by a rod that runs down the column from your lock cylinder. You could test your old one by taking it off the column and with the wires hooked up move the switch through its positions with a pick tool. (Just make sure the car is in park in case it starts) Also with the switch off rotate your key through the different positions and make sure the rod has full travel. And you'll see just how easy it is for thieves to steal these cars. :-O…The mounting holes in the switch are slotted. But I don't think enough that it could be miss adjusted enough so the car won't start/ shut off.
Old Jan 28, 2015 | 05:16 PM
The ignition lock and key have nothing to do with the switch.
Old Jan 28, 2015 | 05:25 PM
76olds's Avatar
Hookers under Hood
Eric, could it possibly be a timing/ or timing chain issue ? Reason I'm asking ...
I had a car back in the day when I shut it off, it would continually run on, I had to shut it off in drive. Never thought much about it, I sold the car not long after.
Old Jan 28, 2015 | 05:42 PM
No, what your describing is runon, or dieseling. What the OP is describing is having power to the coil with the key off.
Old Jan 28, 2015 | 05:48 PM
76olds's Avatar
Hookers under Hood
Cheers Eric, I learned something again today in the event this should happen down the road. I didn't want to side track the OP's question here just my thought.
Old Jan 29, 2015 | 08:43 AM
N2ROW's Avatar
OK thanks for the reply. When I get the car from paint, Ill take it a part and examine the travel of the rods. I guess Ill replace the lock device anyway since im opening it up anyway. I will advise my findings thanks.
304forest
Jan 31, 2015 12:37 PM
Dshelvy
Sep 26, 2013 10:35 PM
Gary's 2 442-S
Feb 16, 2011 07:34 PM
American Lead
Apr 20, 2009 12:47 PM
d.smith1
Jan 30, 2008 12:08 PM
