68 442 power windows slooooow
Old Nov 15, 2014 | 12:47 PM
70vista's Avatar
Hi All,
Doing some stuf on my 68 442 conveertible and one of the things is the power windows which are slow. I got to help them up but seem to go down ok. I have replace the front window motors with little improvement and tried to see if anything is binding and seems to be ok. Could the regulators be worn out?? Anybody tackle this issue with any success?? Thanks Steve
Old Nov 17, 2014 | 07:02 AM
tomsw31's Avatar
Litheum grease on all of the moving parts and guides works wonders for speeding them up and reducing the drag.
Old Nov 17, 2014 | 09:16 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
X2 on the grease. I usually clean the regulators in the parts washer then re-grease. Pull the motor apart inspect clean grease etc...Inspect the rollers replace as needed.
Slow motors can be caused by a prob with the motor, the ground circuit, the switches, the wiring, and a bad window adjustment. If there's too much resistance anywhere it will slow the motor. Check the grounds and the switches for high resistance. Switches could be dirty or burnt.
You could do a voltage drop test. That will help pin point the problem.
Adjustment plays a part here too. If they are rubbing too hard on one of the window guides that wont help.
Thats why I like to remove the entire assembly(after good notes and pictures). Clean test and re-grease. Install and adjust.
Old Nov 17, 2014 | 10:00 AM
Octania's Avatar
Weak magnets will do that
very tough to fix other than a new motor.
Check voltage across the motor and its current draw.
I believe weak mags cause larger current draw but don't produce torque with that power.
Old Nov 17, 2014 | 10:02 AM
lemoldsnut's Avatar
adjustment can help but all of the above is first step. Plus if you installed new window felts they can make it slower too.
Old Nov 17, 2014 | 05:17 PM
70vista's Avatar
Thanks for the replys guys. I have lubed up everything and had the regulater out when doing the restoration on the car. Will check for power and ground problems and the motors are new. Steve
Old Nov 17, 2014 | 06:47 PM
Octania's Avatar
Remember that new is NOT equal to perfect.
Can you test the motion of the window w/o the motor in place? See how much load it is offering the motor?
Old Nov 18, 2014 | 09:05 AM
And hopefully new doesnt mean off shore garbage. An AMP probe on the power wire or an inline gauge will spot over load. Another good tool to have. Let us all know what you find. Close the loop on the thread for future searchers. TX!
Old Nov 19, 2014 | 04:30 PM
70vista's Avatar
I have tried to move them manually with the motor out and they seem to move ok. Unfortunately these are not real gm motors. They were given to me as a gift and look well built. I will have to keep a it and see if I can find the problem. Steve
socalrs
Aug 14, 2012 11:07 AM
dingusboy
May 20, 2012 07:32 PM
squirell
Apr 13, 2011 05:22 PM
rustycarr
Mar 7, 2007 06:24 AM
jrbarrie83
Jul 4, 2006 09:16 AM
