65 Cutlass Convertible top is slooooow
Old Feb 17, 2009 | 04:43 AM
dingusboy's Avatar
The convertible top on my 65 is slow. It also need a little manual help to start its spread over the passenger compartment. It does not appear to be leaking fluid. I was told that the fluid might be low. Any suggestions? Any good articles on convertible top maintenance?
Old Feb 17, 2009 | 05:35 AM
Bluevista's Avatar
Registered
It could be low on fluid. Is the pump quiet with no cavitating noises? First thing to check anyway before you can figure anything else out. Be careful of overfiilling the pump. Those things draw a lot of juice and the wiring connections have to be good too. The car should be running when you put the top up or down or it will be slow, all windows down so it won't bind, especially going up. The correct filling procedure is in the Fisher Body manual, I saw it on team chebelle too. They have some threads in the convertible forum about similar problems too.
http://www.chevelles.com/forums/showthread.php?t=113945
Old Feb 17, 2009 | 06:58 AM
Lady72nRob71's Avatar
See if this post might help you out...
https://classicoldsmobile.com/forums...not-go-up.html
I had attached the bleeding procedure for the '72; not sure how similar it is to '65...
Old Feb 17, 2009 | 02:25 PM
dingusboy's Avatar
Thanks, that's what I needed.
Old May 19, 2012 | 09:05 PM
Dan Bftgog Cassale's Avatar
Top does the same thing
Mine was slow when i bought it & I actually sprayed all the moving parts & it made a world of difference..Best of luck.
Old May 20, 2012 | 07:53 AM
Snowdog's Avatar
Just Got a new top last week and when they had it apart the left piston was leaking.
New top installed $1515.00 Marks in New Lenox,IL
Old May 20, 2012 | 07:32 PM
64Todd's Avatar
Lubrication
x2 on lubing the hinge points. Fluid is important as well as electrical connections. Mine retracts and comes up in about 20 seconds.
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
70vista
Nov 19, 2014 04:30 PM
cfair
Jun 30, 2012 10:07 AM
Bobac455
Aug 27, 2011 03:20 PM
Olds luvr
Dec 2, 2010 08:26 AM
