To use the old wire harness or not?
Old Aug 28, 2014 | 07:39 AM
1968_Post's Avatar
I'm in the midst of a 18 month restoration of my '68 442. I pulled the wiring harnesses early on in the process and recently pulled them out to start the cleanup process. While the main harness itself is in decent condition and needs minimal repair, the fuse box shows a fair amount of corrosion both on the fuse clips and also where the wire connectors attach to the panel.
This car has had an unanticipated plethora of MAW's which have put a serious strain on the budget. I really can't afford to purchase a new main harness. I have a 18 circuit harness available that was purchased for another project and am considering using it as the basis for the underdash section of the harness.
I guess the question is how much corrosion is too much? I recall posts from gearheads78 who restored the original harness but can't recall the condition of the fuse panel.
The last thing I want to do is give this car a reason to go up in flames...
Old Aug 28, 2014 | 07:46 AM
As long as the wiring is overall serviceable, you can burnish the fuse contacts and replace any bad single wires or terminal ends and be good to go.
Old Aug 28, 2014 | 07:51 AM
You can get individual fuse block terminals from one of the wire restoration companies, too.
I forget which one, but there was a post on here about two years ago about it, if I recall.
Old Aug 28, 2014 | 08:16 AM
Jetstarjim's Avatar
Most of the fuse blocks I do are not available new. I use glass bead at low pressure and clean them. Then wipe the contact points with dielectric grease, and spray with detail clear. I have a small blasting gun that looks and works like the old style siphon feed paint guns. I think HF has something cheap like that. Pretty handy little thing for restoration.
Old Aug 28, 2014 | 03:10 PM
Sampson's Avatar
A Dremmel tool with a small wire wheel brush gets in there pretty well too.
Old Aug 28, 2014 | 03:17 PM
tru-blue 442's Avatar
Old School Olds
Could you post pics of your old one?
Was it an a/c car by chance?
I may have an oem unit, under dash side
I think. Shoot some pics and I will looksee
if you want.
JpMotorsports
May 15, 2014 07:08 AM
72cuttys
Mar 28, 2014 04:14 PM
jensenracing77
Sep 4, 2009 05:46 PM
1973olds98
Jul 27, 2009 07:51 PM
