WTF Happened to my battery??
Old Mar 14, 2015 | 03:45 PM
Olds Dad's Avatar
Collector of Stray 55's
So I use a battery tender on my '55 driver, which unfortunately spent the brutal RI winter outside. I noticed that the normally green indicator light had turned to red so I opened the hood (after literally shoveling snow off of it) to see if perhaps one of the leads had come off.
This is what I found - almost looks as if it exploded, but no sign of fire or heat - could it have frozen? I have never seen anything like this.
Thoughts?
Old Mar 14, 2015 | 03:51 PM
NHolds's Avatar
Looks like a critter wanted in...
Old Mar 14, 2015 | 03:54 PM
classicmuscle442's Avatar
Looks like ground cable melted case, did you have to move cable for picture?
Old Mar 14, 2015 | 03:57 PM
Olds Dad's Avatar
No - picture is exactly as I found it - did not have to move the cable. Bone dry inside yet I don't see any signs of acid having leaked out. Like I said, very strange and I've never seen anything like it.
Old Mar 14, 2015 | 04:05 PM
stellar's Avatar
stellar
An infamous quote comes to mind, " what does it matter now" As far as I can tell from the pic, it doesn't look chewed or melted, and if the tender was working I doubt if it was frozen unless the battery was bad anyway. So my best guess was an explosion. In any case I would monitor the tender for under and over charge conditions before I reused it without frequent voltage testing.
Old Mar 14, 2015 | 05:11 PM
Olds Dad's Avatar
I agree - it's a moot point; but I still wonder what happened. I've had old iron for many years and while I've had many a dead battery, I've never had this happen. Just hoped someone out there had a similar experience and knew the cause.
Old Mar 14, 2015 | 06:12 PM
Rocketowner's Avatar
I've known batteries to freeze when there was no charge in them,and even saw them burst the case at the top edge,but yours looks like it exploded.Glad it didn't cause a fire! Larry
Old Mar 14, 2015 | 06:38 PM
Professur's Avatar
Did you find the missing plastic?
Old Mar 14, 2015 | 06:47 PM
I'm with NHOlds - looks like a critter to me.
Some of those things will chew on stuff and you'll never figure out why. I've seen squirrels eat lead roof flashing.
Old Mar 14, 2015 | 07:04 PM
jensenracing77's Avatar
My guess would be a critter also. Maybe he was looking to take a trip on some acid
Old Mar 14, 2015 | 07:49 PM
NHolds's Avatar
Pop the top the rest of the way off and look for a carcass...
Old Mar 14, 2015 | 08:10 PM
stellar's Avatar
stellar
Now that gives me the giggles. Being bone dry inside means the varmint must have taken a long trip or maybe the tender is overcharging.
Old Mar 14, 2015 | 08:12 PM
rjohnson442's Avatar
Mr. Johnson
Looks like a squirrel tried to eat it's way in from the teeth marks. Battery was probably the warmest thing around and he wanted in! You need a new ground cable btw
Old Mar 14, 2015 | 08:20 PM
stellar's Avatar
stellar
Send the battery to Eric for some forensic examination. Don't send it to jensen, he may want to mix any left over acid with some koolaid to see if he can get a charge out of it. Then again maybe he could let one of his employees check it out on one of their unscheduled days off.
Old Mar 14, 2015 | 08:43 PM
HAHAHA... I don't think any of them are into anything like that but anymore nothing would surprise me.
Old Mar 14, 2015 | 08:59 PM
stellar's Avatar
stellar
As a former business owner, I feel your Pain. (The Clinton quotes seem to fit well today)
Old Mar 14, 2015 | 09:11 PM
Octania's Avatar
That is caused when a large electron gets into the system. 110V electrons are much bigger than the 12V electrons, sometimes they get in thru a charger.
or, drunken animals
Old Mar 15, 2015 | 05:49 AM
Ozzie's Avatar
Exclamation
If you have any squirrels where you live, I'll also vote for them. I too have seen them eat the lead roof flashing. I have a friend who took up squirrel hunting because of it. If I had the squirrels' habits I'd probably be dead. One was probably trying to get to those delicious lead plates. Next time put the '55 in a garage with restricted access.
Old Mar 19, 2015 | 07:04 PM
Olds Dad's Avatar
I built a 4 car garage and this one is still outside. 2 convertibles and a hardtop inside along with a lot of stuff...should have built a 10 car
Old Mar 19, 2015 | 07:09 PM
mrolds69's Avatar
Yup, you and me both Gordon!
Old Mar 19, 2015 | 07:13 PM
Olds Dad's Avatar
So I'll sign you up Frank for my first tenant at my new garage rental facility?
Old Mar 21, 2015 | 06:14 AM
twintracks's Avatar
I would also suspect a raccoon. But, I don't think it will be back.
Old Mar 21, 2015 | 07:11 AM
biggus's Avatar
I don't know but it looks like a rat to me. I think I'd be checking the rest of the car over pretty close.
Old Mar 21, 2015 | 02:15 PM
4Speedy's Avatar
Thoughts?
Looks like a short between the battery plates.
Seen other similar issues Like yours.
Texas442
Mar 28, 2013 07:13 PM
w-30dreamin
Jan 9, 2010 03:19 PM
Jamesbo
Oct 23, 2008 07:43 PM
J-(Chicago)
May 26, 2008 08:51 PM
