86 Cutlass electrical problems (PLEASE HELP)
Old Nov 14, 2014 | 08:06 AM
NMcCarthy's Avatar
head lights tail light brake lights dash lights will not work.
although the blinkers work.
Okay so cant find a fuse in fuse box for head lights first off checked all others are good.
I pulled the head light switch out and tested for power to all terminals, NOTHING
but what is weird on that note is the dial for dimmness and to turn on the dome light works with doors closed turn dial all the way up and the floor board lights kick on. I keep asking myself if i checked for power at all terminals that plug into both of those switches and get nothing how in the heck is that part working? I did test the light on another power source just to be sure i had a good ground.
I ran a power wire from battery to the point where the headlight switch plugs into and my headlights turned on, never could get tails though.
as far as the brake lights I believe my button on the switch at pedal is jammed up in side the switch itself telling it the brakes are not being applied.
any and all help would be very much appreciated. thank you
Old Nov 14, 2014 | 08:10 AM
NMcCarthy's Avatar
Also while were on the electrical subject------
there is a spot on the drivers side of my TH350 transmission for an electrical plug...... what is this for?
Old Nov 14, 2014 | 08:13 AM
That's because there isn't one. The headlight switch has a circuit breaker built into it for the headlight circuit.
chasman414
Jun 25, 2020 07:05 AM
Hurst/Olds 73/74
Oct 16, 2014 06:22 AM
Beob
May 16, 2011 06:43 PM
MN71W30
Feb 26, 2009 05:59 AM
Jolly Green
May 28, 2008 04:43 PM
