1965 (66?) 88, 98 series (all big cars) Horn relay replacement solution!
Old Nov 14, 2014 | 01:34 PM
StarGeneral's Avatar
This thread is for those of you that own a 1965 big car (88, 98 series, Starfire, w/e). The original horn relay for those cars is not reproduced and is a junction block/horn relay combo that looks like this:
Do not waste time having auto parts guys try to look up interchange for you, because there is none that accomplishes both the function of junction block AND horn relay in one part. You will need to improvise.
You can eliminate the junction block stud on your wiring harness and just mount a standalone one to your inner fender like so:
You can just buy this part (Duralast 16127) and run a hot wire from the non side-by-side spade terminal to the junction post:
Your OEM harness connector will connect right to the newer style relay without any modification and work perfectly (I have tested it on my car). This part costs 6.49 in comparison to NOS horn relays which I have seen go for over $100. The only added cost is getting the junction post.
Old Nov 14, 2014 | 02:00 PM
The 66/67 A body replacement relays have the junction block built in also.
Old Nov 14, 2014 | 02:05 PM
Right you are sir I think the 66-67 relay looks like this:
Old Jul 29, 2024 | 08:21 AM
GCH's Avatar
GCH
Old thread but thanks for tip about a new horn
relay . I should se if i find a new one to my -65 98
I followed Joe P advise testning the relay in this thread :
Horn Issue - 69 Cutlass - ClassicOldsmobile.com
I guess i can use this also , crossreference to Duralast 16127
Old Jul 30, 2024 | 12:45 AM
GCH's Avatar
GCH
Hmmm , was looking in some boxes and find a couple of hornrelays (?) from newer cars ,
Nr 344813 and 25523703. The relays connection looks similar to the relays above but i
don´t know if they will fit my -65.
The original relay has a "tab" on the connection spade that goes to the green wire in the
oem connection.
Old Jul 30, 2024 | 12:31 PM
ourkid2000's Avatar
Unless I'm missing something, just get one of these. My '66 Toronado uses the same one that is pictured in the first post. The replacement one from Fusick bolted right in and worked perfect for me. It doesn't look exactly right but it does the job.
Old Jul 31, 2024 | 12:53 AM
GCH's Avatar
GCH
Thanks for tip , have seen this relay here for $ 180 but not in stock. My relay in my 88 works so
i should try this in the 98 to se what happens and on the contrary.
Old Aug 1, 2024 | 05:05 AM
GCH's Avatar
GCH
Tested the relay from my 88 in my 98 and now
the horn works fine with the steering wheel buttons.
Should keep this relay in the 98 when we use this car a lot more
Here is how the faulty relay looks inside :
Littelfuse.inc on the top cover
Old Aug 5, 2024 | 06:57 AM
GCH's Avatar
GCH
I used relay 344813 and this worked fine , the
tabs on relay fits the oem female connector.
And then a wire to the + stud. Well , it dont looks
like original but works , and it can be back to original again .
Ps , it also worked with my 25523703 relay.
Delta425
Jul 13, 2022 05:39 AM
srholt45@gmail.com
Nov 19, 2015 09:34 PM
70olds455
Nov 15, 2012 06:15 PM
RandyS
Sep 1, 2012 04:42 PM
64 Cutlass
Aug 1, 2009 06:22 AM
