what causes a voltage regulator to stick?
Old Apr 4, 2015 | 08:02 AM
Tedd Thompson's Avatar
Yesterday I went to a car show about 50 miles away, amp meter showed full charge as I left the house after start up then settled down to slightly past the + charge side as it should. I had the lights on the whole way but I didn't notice till later that the amp gauge was now reading a slightly negative charge at any RPM and the car turned over very slowly on start up. Lights were now off.
I never made the show because of this and beat feet back home running on the battery.Thirty miles down the road the amp gauge started moving from a negative to a positive + 5 then later to 15 amps. At home I shut off the motor and tried to start the car which it did, battery showed 14.1 volts on my multi- meter earlier it was at 12 volts. After another start the Amp gauge went to full amps then settled down as usual. The question is what would cause this, do amp gauges stick and what should be done to fix this, replace repair or what? Generator battery and voltage regulator all have about 1000 miles from new. Tedd
Old Apr 4, 2015 | 08:16 AM
CutlassDad's Avatar
One of the 2 contacts is intermittently sticking closed.
A dead battery after a period of sitting is likely a regulator problem.
My '70 CSM has the diagram and a thorough description of the regulator operation.
Old Apr 4, 2015 | 10:01 AM
To expand on the prior post, mechanical regulators have several sets of contact point that open and close to regulate the voltage. Every time they open, there's an arc, which causes a minute amount of damage to the points. Over time this creates roughness, which causes resistance, which causes heat, which causes the points to overheat and "weld" together. Just like the points in your distributor, they need to be replaced periodically.
Old Apr 4, 2015 | 12:10 PM
Ozzie's Avatar
I agree with what's been said thus far. It's probably not the gauge, but rather the regulator. About 40 years ago mine stuck once in TN resulting in a full charging condition which almost cooked the generator. Don't let it charge "all out" for an extended period. I had to disconnect it until I was able to replace the regulator. In theory, you can clean the contacts & recalibrate the regulator if you want. See the shop manual for details (Section 13). Many people just replace it.
Old Apr 4, 2015 | 02:57 PM
Thanks guys, I took the car for another 50 mile car show trip today and not a hint of a problem but if it does this again I'm going to swap it out, might even buy one and put it in the trunk along with the rebuilt starter, extra set of points and condenser, extra oil filter, gallon of oil, tire chains, tool box, pop up and three lawn chairs... Phew no wonder the trunk is full....... Thanks for the incite ...Tedd
Old Apr 5, 2015 | 09:22 AM
rustyroger's Avatar
'87 Delta 88 Royale
I've had a great idea Tedd!. Get another '55 Olds, put it on a trailer, hitch it to your car, and haul it to the shows. You'll never be stuck for a spare part.
Roger.
Old Apr 5, 2015 | 09:47 AM
Dooooh
Old Apr 5, 2015 | 10:23 AM
Roger.
Hahahha.
Old Apr 6, 2015 | 07:37 AM
You would think that I shouldn't be having these problems, most everything on my car has been rebuilt or replaced Now I'm having problems with stuff I've already replaced going bad. Like they say you are never done....Tedd
delta_88_germany
Feb 22, 2014 01:48 PM
oldman72
Sep 24, 2008 08:05 PM
ow30442
Sep 2, 2008 02:51 PM
rocket69
Aug 14, 2008 09:09 AM
and1stp
Sep 17, 2006 07:31 PM
