No instrument lights? cutlass 1968
Old Dec 4, 2014 | 10:47 AM
Teamcamber's Avatar
Hi!
My instument light does not work on my gauges. But when I open the door does the map light work. Anyone that can help me?
Old Dec 4, 2014 | 10:51 AM
Is the **** on the headlamps turned almost all the way to the left?
Old Dec 4, 2014 | 11:22 AM
Is the INST fuse blown?
Old Dec 4, 2014 | 03:58 PM
The insument lamps are powered from the tailights, no taillights, no instrument lamps. Make sure the tailight fuse is good, make sure the tailights work. The instrument lamp feed from the headlight switch is green, it comes out the other side of the intrument lamp fuse as gray.
Old Dec 5, 2014 | 07:17 AM
Just to clarify, the instrument lamps actually are powered through two fuses in parallel. The tail light fuse provides power to the headlight switch. This is split off in the switch to the rheostat that controls brightness of the panel lamps (as noted, be sure the **** is turned CCW for brightest lights). It then comes out of the headlight switch and back to the fuse panel where it passes through the 4 amp fuse for the panel lamps.
Old Dec 5, 2014 | 08:10 AM
Series, Joe. Series.
Old Dec 5, 2014 | 08:54 AM
DOH! I was saying series as I typed parallel...
Once again, I shouldn't be posting while I'm participating in a telecon at work.
Old Dec 5, 2014 | 09:18 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Even the great Padavano is only human and surely allowed mistakes, especially when multi-tasking
deltaroads
Oct 26, 2015 04:08 PM
arod40
Jun 15, 2013 11:16 PM
68RocketAction
Jun 7, 2013 09:21 PM
Dshelvy
Mar 19, 2012 08:12 PM
dhoff
May 28, 2010 05:19 AM
