No instrument panel or tail lights
Old May 30, 2013 | 11:47 PM
arod40's Avatar
75 oldsmobile delta 88 , Replaced headlight switch and I have no blown fuses. Still no tail or instrument panel lights not sure where to go for here. Brakes and headlights work correctly. Any suggestion? Thanks
Old May 31, 2013 | 07:32 PM
Lady72nRob71's Avatar
Did you actually replace the fuse or test it? They can be broke at the ends and still "look" okay. Happened several times to me.
You can measure across the fuse with a volt meter. 0V it is okay, 12V it is bad.
Old Jun 7, 2013 | 09:10 PM
arod40's Avatar
Thanks for reply I will replace all fuse and see what happens.
Old Jun 15, 2013 | 09:51 AM
arod40's Avatar
Tail light issues
Ok took your advice replaced every fuse replaced headlight switch... Now my parking light work .. Thanks.. Only issue is the no lights to Instrument panel ..the brake light on panel lights up and left side blinker light also work on panel, but nothing else. Thank for the advice at least I got the parking light working.
Old Jun 15, 2013 | 12:08 PM
Did you try turning the dimmer rheostat on the headlight switch?
Old Jun 15, 2013 | 12:50 PM
Look to see if you have a 4A shorty fuse for INST LPS or such. If so check it also.
I have had a rheostat on a new chinesium headlight switch to be bad just after installation, so that is another posibility.
Old Jun 15, 2013 | 11:16 PM
arod40's Avatar
Thanks again for info
deltaroads
Oct 26, 2015 04:08 PM
carnell71075
Apr 12, 2015 04:09 PM
Oldssupreme
Apr 3, 2015 08:36 PM
JATA
Jul 10, 2013 06:46 AM
68RocketAction
Jun 7, 2013 09:21 PM
