Electrical connector question on '56 Olds
Old Jun 4, 2014 | 07:13 AM
JackJack56Olds's Avatar
Does anyone know if this electrical connector from a '56 Olds come apart in away way. I'm trying to remove everything that holds the radiator and ac together and the wires run through the brackets. I don't see how I can disconnect any of the wiring to take it out of the vehicle.
Old Jun 4, 2014 | 07:42 AM
Olds Dad's Avatar
Collector of Stray 55's
The leads from the turn signal and the headlights just pull out of the connector - the plastic assembly itself does not come apart - just gently pull the wires from as near the connector as you can - they're just male blade connectors and they should slide right out
Old Jun 4, 2014 | 07:50 AM
Of course, if it didn't come apart, it wouldn't be a "connector", it would be a "splice"...
Old Jun 4, 2014 | 09:08 AM
it looked like they were terminals but was too afraid to start yanking on them. 50+ years of being connected may prove challenging.
Old Jun 5, 2014 | 03:04 AM
Yellowstatue's Avatar
Back then they didn't realize that they needed locks on the terminals and plugs too. The new stuff has locks to lock the locks!!! Plus frilly little collars to keep the dust and damp out.
Old Jun 5, 2014 | 04:58 AM
Olds Dad's Avatar
I've pulled apart quite a few - even ones that looked like they were salvaged from the Titanic's resting site - and most slide out with ease! If you're reassembling them, buy some electrical contact spray cleaner, 'hose' it out good, and reassemble with a nice smathering of dielectric grease. I always clean the male blade with some emery cloth, and the female slot with a very thin file.
Old Jun 5, 2014 | 09:57 AM
Funny thing, these looked like the same thing. Green growth all over them. Also slid out very easily with some needle nose pliers.
Dbechtel71
Mar 30, 2015 06:52 PM
Iggyg00
Sep 3, 2013 08:40 PM
misercola
Mar 5, 2012 01:13 PM
tarheeldoc
Jun 3, 2009 06:42 AM
woodie582
Nov 7, 2008 01:07 PM
