67 C/S rear bumper install wiring
Old Mar 30, 2020 | 08:33 PM
brianbeez67's Avatar
After some great amount of elbow grease I'm ready to put my rear bumper (with all new bulbs and lenses) back on the car. But the tail lights & backup lights wiring has the rubber grommets that seal the
trunk opening. This rubber grommet is stiff and basically stuck in position on the wire. Does anyone have any suggestions on how to loosen this grommet so I can
adjust the wires to fit better (How do I slide the grommet on the wires). As always any help is always welcome. Thanks Brian
Old Mar 30, 2020 | 10:20 PM
Try sitting it in the sun for a couple hours.
Old Mar 30, 2020 | 11:17 PM
Bfg's Avatar
Bfg
Try using a hair dryer to soften the rubber
Old Apr 1, 2020 | 12:22 PM
67 cutlass supreme owner
I have a heat gun on standby, thanks I'll let you guys know what happens
Old Apr 19, 2020 | 08:53 PM
67 cutlass bumper wiring
Had the pleasure of using a heat gun on an old wire and pulled the covering rite off the wire, not good. So I just went at it and the wires and the rubber pieces were all in the correct spot to connect the wires thru the trunk openings, all good so far.
Then I looked at the wiring for the tail lights, no grommets. I went to JEGS and ordered 7/8" rubber grommets (without holes in the center). Drilled a hole in the center and made a slice for the wires. Great
fit darn happy. Went to work with a smile on my face that day. Bumper on = smiles all around.
brandon reynolds
Mar 20, 2018 05:26 AM
GasLaneGreg
Jun 20, 2014 12:26 PM
ent72olds
Mar 28, 2014 02:07 PM
60193W30
Dec 12, 2012 02:54 PM
Steve Wike
Apr 13, 2010 04:57 PM
