One step forward, 1/2 a step back
Old May 10, 2020 | 04:53 PM
I updated/replaced some of the add-on gauges to my car. I installed electric full-sweep Autometer Ultra-Lite oil pressure, water temp, fuel pressure, trans temp, bolts, all with built in warning lamps. I specifically asked for full electric sweep gauges. I should have looked a little closer before installation. 😡
The gauges all have regular 194 bulbs for backlighting, EXCEPT the trans temp (it’s a ULTRA-LITE II) that has LED backlighting. Autometer doesn’t offer the other gauges in the ULTRA-LITE II model full sweep electric with LED backlighting. So, I either have all full sweep except the trans temp, have all incandescent lights except the trans temp (which can’t be dimmed with the dash dimmer) or convert all the gauges to LED lighting, and add a PWM module (pulse width modulation) to dim the LEDs.
Autometer offers a PWM driver, from what I understand it has a dial to adjust the brightness. It can’t be adjusted from the headlamp rheostat. Anyone in readerland have any suggestions?
i have had some of these gauges for over a year, so exchange is out of the question. I like the Autometer brand, so a different vendor is also a no-go.
Old May 10, 2020 | 06:14 PM
oddball's Avatar
In mine, the three gauges in one of Randy's pods aren't connected to the dimmer and are a completely different look than the other gauges. In the end it totally doesn't matter.
Just drive it and see if it really bothers you. It might be easier to ignore than to ""fix"".
Old May 10, 2020 | 07:14 PM
I've found most of the time it stays on full bright anyway.
Old May 10, 2020 | 07:58 PM
RandyS's Avatar
Or maybe convert the led to incan. They run on the same voltage, and then they would all be dimmable with the rheostat.
Old May 11, 2020 | 04:12 AM
Unfortunately, that’s not an option. The LED are internal, and mounted to the circuit board. There isn’t a place to put a 194 bulb.
Old May 11, 2020 | 07:02 AM
RandyS's Avatar
Can you post a pic of the board? It may still be possible to change out the bulbs. (though as you say, not 194's)
Old May 11, 2020 | 09:32 AM
As I said, they are internal, and I don’t see a way to open the gauge. The bezel is crimped to the housing.
Apr 10, 2019 06:11 PM
rktolds
Jun 18, 2018 04:08 PM
PowerToTheMaxx
Apr 4, 2015 05:49 AM
Fear Reborn
Sep 24, 2013 04:22 AM
citcapp
Dec 14, 2009 11:10 AM
