Fasten Seat Belt Light is haunted!
Old Oct 6, 2020 | 02:15 PM
DwightSull's Avatar
Drop Top Delta 88
Hey Y'all,
I have a '75 Delta 88 Convertible, and the Fasten Seat Belt light comes on whether there is someone in the passenger seat or not (seat belt is fastened). Some of the circuit was already disconnected when I got the car 20 years ago and it went away when I had some work done on it 10 years ago. I recently upgraded all the bulbs to LEDs and I must have accidentally connected it back up while I had the dash apart to replace bulbs.
I've disconnected every wire I can find under the seat, but the light still comes on after a few minutes in Drive and never goes out until I put it back into Park. I've looked (unsuccessfully) for a wiring diagram for the car, but what I really need to know is what color the wires for this circuit are. Any information on the system design and sensors might be helpful in finding a work-around (like disabling or wiring around the sensors). This should be a simple problem to fix, but I'm missing a couple specifics that could help me avoid taking the dashboard apart again.
Any help would be greatly appreciated!
DwightSull
Old Oct 6, 2020 | 06:03 PM
Can you post a pic of the wiring diagram? On the later cars, the chime module supplies power to the seat belt light. If your car is the same, it should be pretty easy to pick the wire out of the connector
Old Oct 6, 2020 | 07:06 PM
DwightSull's Avatar
Drop Top Delta 88
Old Oct 6, 2020 | 07:10 PM
DwightSull's Avatar
Drop Top Delta 88
Wiring diagram
Hi Matt,
I don’t have wiring diagram for my car. I found one from a 1970 Cutlass, but it doesn’t contain a seat belt light at all.
Old Oct 7, 2020 | 05:24 AM
Hopefully someone can post a diagram. Without knowing how the seat belt light is wired it’s hard to figure out a way around it.
Tiberian Fiend
Feb 12, 2019 02:51 PM
jja18
Sep 12, 2017 10:34 AM
AJFink
Nov 9, 2015 08:48 AM
88hurstolds
Oct 10, 2015 09:07 AM
costpenn
Jun 26, 2011 11:59 AM
